Solved Audio stuter when multitasking with mpc and youtube
sharif9991
Bread scientist
Jeddah
When I watch YouTube videos, or videos/music in MPC my system audio stutter when multitasking
this also happens during watching a video but its a very short stutter and the whole immersion gets lost away............
I noticed this all started to happen after i brought my GPU back to life the 2nd time also not sure if its related but i have been having few problems with Google chrome its a bit better after i disabled hardware acceleration but its all good with Firefox apart from YouTube but YouTube stutters worst when multitasking in chrome
  • The video render-er i use in MPC is madvr
  • MPC (K lite codec pack) is updated
  • My GPU Power colour HD4870 1 gig version
  • Drivers updated latest (GPU)
  • When i was taking about bring it back to life i was talking about baking it.
  • Sound card Xonar DG
  • Drivers updated using beta version
  • My CPU utilization didn't reach 100 nor 60%
  • My GPU utilization doesn't go above 4%
I "temporally" solved it back then by
Installing bunch of windows updates
plus not only that problem also my chrome problem is fixed
For few thing i tried check this thread at LTT
Audio stuter when multitasking with mpc and youtube - Operating Systems and Software - Linus Tech Tips
    w8.1 pro
    custom
    AMD Phenom II X4 955 Black Edition
    ASUS M4A785TD-V EVO
    kingston 8gb
    GTX 970 STRIX
    ASUS xonar DG
    Dell U2412M,LG 24MP55HQ
    1920x1200,1920x1080
    1tb+500gb
    Corsair CX 600 watts
    Thermaltake M5
    Cooler master V6
    Logitech MK260 Combo with the mouse but not using the mouse
    Logitech G400s
    40mbps
    chrome/firefox
    controller>xbox controller
After yours "shake and bake" small wander you are experiencing problems. Did you try disconnecting that Xonar and using audio from MB and while we are at it, is sound on MB disabled in BIOS ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
This happened before my 2nd bake as well but not that often and the audio/video stutter effect was lower
Oh after i restarted my computer yesterday it was fixed but it comes back after a while though and it normally gets triggered when, i have any multimedia opened at the background while i use chrome or when i watch youtube video but that one happens in randomly while watching bunch of youtube videos one after another
Should i disable onboard audio?if it is currently on(if a option like that is there in the bios)
the problem with removing the soundcard is the problem gets fixed when i restart the computer
those .net framework have anything to do with this?
yesterday when i wa about to restart i got this error and i took screenshot
Ignore the emptiness,its normal (rainmeter+rocketdock was closed as i was about to restart when i canceled it to take a screenshot)
    w8.1 pro
    custom
    ASUS M4A785TD-V EVO
    kingston 8gb
    GTX 970 STRIX
    ASUS xonar DG
    1920x1200,1920x1080
    1tb+500gb
    Thermaltake M5
    Cooler master V6
    Logitech G400s
    40mbps
    chrome/firefox
[DEL]Update its has to be .net framework after i used the .net framework repair tool it fixed it but after few days (i did it few days ago when making this post)but now i have a different problem where all my browser are super slow (they are taking forever to load up outlook itself) so i used the repair again and it fixed it but came back again
i will try to reinstall it[/DEL]
Never mind sorry it is actually my ISP acting weird today
    w8.1 pro
    custom
    ASUS M4A785TD-V EVO
    kingston 8gb
    GTX 970 STRIX
    ASUS xonar DG
    1920x1200,1920x1080
    1tb+500gb
    Thermaltake M5
    Cooler master V6
    Logitech G400s
    40mbps
    chrome/firefox
[DEL]i think that problem might have been fixed after using the .net framework repair tool but i am not completely sure i will report back after few days of "making sure"[/DEL]
Yup its still here
    w8.1 pro
    custom
    ASUS M4A785TD-V EVO
    kingston 8gb
    GTX 970 STRIX
    ASUS xonar DG
    1920x1200,1920x1080
    1tb+500gb
    Thermaltake M5
    Cooler master V6
    Logitech G400s
    40mbps
    chrome/firefox
After months of suffering,pain,anger and agony I finally found the solution
Virtual memory/paging file that i had on my 2nd HDD after removing and restarting its been okay for 24hrs :)
    w8.1 pro
    custom
    ASUS M4A785TD-V EVO
    kingston 8gb
    GTX 970 STRIX
    ASUS xonar DG
    1920x1200,1920x1080
    1tb+500gb
    Thermaltake M5
    Cooler master V6
    Logitech G400s
    40mbps
    chrome/firefox
