Noise/Buzzing Heard in Headphones when Sound Unmuted
  1. #11
    This is what I'm wondering. I think it has to be a driver problem.
  2. #12
    May not even be the sound driver, could be some other device but it causes the sound. What is different between Windows and Linux? Are all the same devices used in Linux? Look at Linus and see if some device (or devices) that are used in Windows are not used in Linux.
Page 2 of 2 FirstFirst 12
Buzzing Noise when headphones are plugged in.
Whenever i plug in my headphones, i hear a buzzing noise. its not the headphones problem, i tested them on other devices and there was no problem. I even changed speakers but i still have the prob, Please Help, ty. :(
blackscreen and buzzing noise from speakers
so yesterday i got a random blackscreen and my headset came with a buzzing noise,while i was watching youtube. there were no bumpfile nor anywhere in event viewer were it said something had crashed. ive took the card out and made sure that everything was plugged well in. today it happend again...
Drivers & Hardware
Crackling noise in any headphones I use. Please help
When i use my headphones the work just fine for a while but then a crackling, popping noise begins. It happens whether i am listening to audio or not and it has happened with 2 pairs of headphones and a set of speakers that plug into the headphone jack in front of my computer.i have no idea if...
Monitor LED blinks and makes a buzzing noise in hibernate.
I have an ASUS LED monitor and an MSI motherboard. When the computer goes into hibernate the blue LED indicator on the face of the monitor blinks. When it starts blinking there is a slight buzzing noise that is emitted. Since my computer is in my bedroom I was hoping to be able to change this so at...
Drivers & Hardware
Irritating buzzing noise
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
Drivers & Hardware
static noise when plugging in my headphones
I have the asus s400ca it has the microphone and headphone in the same jack. My headphones are fine in any other laptop but when I plug them into my new asus I hear very loud static even when playing music. It came with via hd audio and I can specify any other information if necessary, please...
buzzing sound and some lag
I need help ,some times I get this low buzzing sound in windows 8 while playing audio/video files and while gaming , It only happens for a couple of seconds , 2-4 seconds and then everything goes back to normal . this happens a lot of times . I'm using windows 8 pro 64 bit running the os...
Performance & Maintenance
