USB Audio Issues
    USB Audio Issues
    I have a Blue Tiki USB microphone. But the audio input is very low and i went to the sound settings and turned it up and it made no difference, The boost microphone slider was missing, i also turned the sensitivity in beats audio ADWare than came with the laptop because my laptop has beats speakers.
    I was wondering if there is a way to get the boost microphone slider back, or some software you do what disc mounters do but with audio and with a boost
    this what i normally looks like: Gyazo - 5550f1e7f62d23eb251f8d1f6ef965a6.png
    What mine looks like : Gyazo - d1f88ce1ef59c880221a63b3c876b16a.png
    Thanks for reading
    Try an uninstall/reinstall of the microphone. With the mic connected (and on if it has a switch), go to the Device Manager and it should be listed under the Sounds section (if detected). If not, you will probably have an Unknown device listed in the USB section.
    Whichever section its in, RIGHT click on the entry for the device to highlight it and then LEFT click "Uninstall". Disconnect the mic from the PC. Restart the PC and after Windows has initialized connect the Mic and Windows should detect it as a new device and reinstall. Assuming this worked at one time, this should fix it.
USB Audio Issues
Having a lot of issues with windows 8. (audio/video/more)
Okay, let me flat out start with, I can NOT stand to use windows 8.1. I am very familiar with W7 and XP but windows 8 just looks, and feels like it was made for a 9 year old who out grew his tablet. I have had this machine for about 3 months now.... I honestly do not enjoy using it...
Audio Issues With Lenovo Z710 Ideapad
Hey, I have an afterglow headset for gaming. It has a line out 3mm headphone jack on it, and a USB. Usually, the USB controls the Mic, and the headphone jack controls the audio. But when I plug it in, the sound is coming through the USB (Chat volume), unless I plug it into another power source,...
Audio issues (Static + crackling) and high audio latency
After having my motherboard, graphics card and RAM replaced due to a power surge, I have been experiencing high audio latency, along with very poor sound quality which includes static noise, crackling. The sound is similar to that of an untuned radio. The sound...
Realtek audio issues
So I've been having issues with the Realtek HD audio drivers on my Sony VAIO laptop (model number VPCCW21FX). No matter what version of Windows I use (Windows 7 or 8), the Realtek Audio Manager will not open. Currently, I am running Windows 8.1 x86 on my laptop. Before, I was using the Microsoft...
Audio Recording Issues
I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1 I am having one problem, most likely user error. When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very...
New here, audio (specifically mic issues)
Hi as the title suggested I am new here. Usually I like to contribute before asking too many questions but I come in a time of need. I will explain my issue: I am using a Windows 8 (64bit) Samsung NP350V5C-A08UK. Yesterday I plugged in a pair of apple headphones(with the mic) straight...
Realtek Audio installation issues
I recently upgraded my PC (Foxconn motherboard) to Windows 8 and downloaded what I understand to be the latest Realtek high definition audio driver ie The driver happily installed but at the moment is a bit reluctant to make an appearance among devices listed in the Device Manager. ...
