DEVEDE conversion error Uncheck use FFMPEG
    Hafnarfjörður IS
    HI there
    To any who are using DEVEDE on Linux (Host or VM) for creating DVD structures / isos / discs from AVI / MKV / MP4 etc files who (usually RARELY) receive Conversion error -- simply uncheck in Edit==>preferences the Use FFMPEG instead of MENCODER for videos --that fixes it. It's very rare that you get this message but it can appear.
Mouse conversion in 8.1?
I have a USB mouse and keyboard set, both paired to the same USB receiver, both have worked perfectly fine until I turned my computer on today. My mouse cursor moves up the screen when I move the mouse downwards and vice versa, however left and right is fine. There are no options for choosing an...
Drivers & Hardware
can't uncheck read only
permission is full control, but still can't uncheck read only on win 8.1
Do For All Dialog Checkbox - Check or Uncheck in Windows 8
Set to Check or Uncheck "Do this for all current items" Dialog Checkbox by Default in Windows 8 and 8.1 This tutorial will show you how to set to always have the "Do this for all current items" confirmation dialog checkbox to be checked or unchecked by default for your user account in Windows...
Can't uncheck read-only
Hi all, I searched a lot, but i can't find a solution. I can't uncheck the read-only attribute on a folder. I uncheck it, click ok, but afterwards is back to read-only. The files in the folders aren't read-only only the folder itself.
Conversion to a 64 bit operating system.
I have a 64 bit processor running 32 bit Windows 8. If I were to install the 64 bit Windows 8, could I restore the 32 bit System Image and preserve my files and settings? Thanks, Kent
Installation & Setup
I have installed windows 7 trail on my oracle virtual box and I have saved in the format .vdi I need to attach it to my windows 8(host os).. How do I convert its format to .vhd
suggestions for HID touchscreen conversion
Hello all. I've decided to undertake a little tablet project, converting my OC'ed HP mini 311 into a windows 8 tablet, but am not sure what touch screen conversion kit is fit for purpose. I'm looking to get the 'full' multitouch experience out of windows 8. Am i right in thinking that i would...
Drivers & Hardware
