Accidentally deleted my IDT sound driver and can't find it
    I accidentally deleted my IDT sound driver for my HP Pavilion G7 laptop. I was going through the programs that I wanted to uninstall and came across the sound driver. Not knowing that it was an important part of my computer, I deleted it. I've tried downloading it again from the internet, but the file isn't working either. My computer is on Windows 8.1 if that helps.
    If you just deleted the driver, then reinstalling would work. Apparently more than the driver was deleted.
    Rebooting, if no vendor driver was found, Windows will install the generic, basic function, HD Audio Codec.
    If that is not installing there are more problems than just the sound, and whatever you uninstalled/deleted must have caused it. if you have a System Restore point that is BEFORE whatever you did, that MAY get you back working. Otherwise, with the OS compromised to the point no sound driver will install it may take a complete reinstall.
    Like I said in a diff thread, and what FB says above.
    1. windows will reinstall a generic device. 2. Go to the makers for a download, they all have them. 3. Sys Restore. The final option I feel is a bit drastic, to have to do a complete reinstall when, I feel a reboot does the same thing.
I accidentally deleted atheros driver
Hi. So I was erasing malware and junk off my laptop (Satellite C855) trying to get rid of any viruses and I accidentally deleted Atheros AR8162/8166/8168, I later found out that my wifi was no longer working, What should I do? Is it a simple fix or should I send it out to a shop? -Thanks
Drivers & Hardware
(Accidentally) Deleted EFI Partition, can't boot.
Hello, I recently partitioned my Asus ROG G750JW into 2 main parts: One 300GB for a mackintosh, and one 6** (remaining space) for windows 8. That worked fine, until I tried to format what I thought was random partition with a size of 128MBs. I believe this to be the EFI partition, and you know...
HELP! Accidentally deleted wow6432node from registry
So I was trying to install a program which required I delete a single item from the wow6432node but I accidentally tried to delete the entire folder from the registry. Now my computer starts with a bunch of weird symbols on thee screen and I cannot sign in. I have tried staring while holding...
Accidentally deleted these programs!
What should I do to re-install them? Please help.
Software and Apps
accidentally deleted administrator, what to do now?
i accidentally changed my admin account into local account now i can't install apps and do anything with it. help please 25767 whenever i try to install some apps it always say.. type an administrators password but then i dont know how to. all i remember was that before i change my account into...
User Accounts and Family Safety
I need help, I accidentally deleted my windows account.
I have windows 8 and I was on my live account. ( On when I accidentally hit the delete account button and I wasn't paying attention and ended up deleting it. The problem is, my windows 8 user is registered with my live account. So it says the live account email. But it's deleted. How can...
Accidentally Deleted My Desktop App...How To Get It Back?
Release Preview - I stupidly deleted a .ini file thinking it was spurious and now my Desktop no longer is listed on the Metro Screen. Suggestions? I don't have a restore point unfortunately.
