Sound issues in the front panel of the computer
RAMWolff
RWC, CA USA
Hi,
I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card.
Not sure what other info will be needed.
I'm running 8.1 currently updated.
PS. If you need my system specs they are filled out, so click on the "my specs" link at the bottom of my post.
Thanks
    Windows 8.1 64 bit
    CyberPower
    Intell Core i7 5820K
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    NVIDIA GeForce GTX760
    on board
    ViewSonic 27" and 20"
    27":1920X1080 20":1600X900
    Toshiba 1863GB SATA
    liquid
    Logitech M570 Marble
    MS default
I would check the connections from the motherboard to the front panel. Unlike the rear connections that are part of the motherboard, you have cables running from the motherboard to your front panel. According to your user manual, the connection is the F11 connection at the bottom. Make sure the pins haven't come loose.
    Self Built
    Intel I-7 860
    Asus P7B
    8GB
    Nvidia 580
    Acer (Primary), Asus (secondary), Sony TV (third)
    Kingston 128GB SSD Windows 8 Boot Drive
    WD Black 1 TB (2 ea)
    WD Red 3 TB
    WD Black 500GB
    MS 1000
    MS Flip
    Verizon FIOS 35/35
    IE 11, Google Chrome, Firefox, Opera, Safari
    Windows 8 Defender (MS Security Essentials)
I just got the computer seated and it's kinda sealed into it's limited space so I'll have to look into that perhaps tomorrow. It's been a day to say the least. Thanks for the info!
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
Well I got curious. I pulled the computer out just enough to get the mic plugged into the main mic output in the back to the card directly (Orange colored one I think?). Nothing. So looks like it might be the card itself. Getting the headphones to cooperate was a hassle so perhaps this card is on it's way out. I've checked for updates to the drivers and they are all updated. All that Creative Auto Update tells me is that it's a Sound Blaster Audigy card. No other info. System info won't tell me either nor this little utility I have called Speccy!
So I guess I'm in the market for a new card. Suggestions?
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
According to the spec of your MB. The built in Audio is a Realtek and I guess you are using an add-on Audio Card from Creative. Did you disable the on board Realtek Audio ?
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Hi, Yes, I did that through the BIOS. I did make a booboo... It was the blue input for the mic. That works from the back. So perhaps it is the front panel after all. I'm so out of practice with computer innards not sure if I really want to deal with that. Wondering if there was a good USB headphone set out there that is good. Perhaps that would hook into the audio and give me what I want but then I'd hope that it would mute the speakers.
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
OK, The cable that connects to the front jacks usually has 2 connectors, one marked with AC97 and the other marked with HD Audio. Which one did you use to connect to the Creative Audio card ? it should be the HD Audio, have you checked that ?
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
The BLUE connection is not the mic input. The PINK colored jack is the industry standard for a mic. PC microphones require +5VDC which is on the "ring" connection to operate.
Also, if you are using the computer's front panel connection, it must be connected to the SoundBlaster sound card, not the motherboard sound connection. The motherboard sound connection point is only for the integrated (on the motherboard) audio.
Windows will not let you use 2 sound devices at same time. Another thing is that Audigy is not supported with win8 at all. Audigy4 is the oldest supported SB and even that one with great difficulties. In any case, newest Realtek codecs are better than those old SBs.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I kinda figured the SB Audigy was way way outdated. So what card would any of you suggest? I'm not into playing games but do watch Netflix on my large monitor and listen to music so nothing way out there with too many settings.
Oh and yes, I thought that the orange or pink WOULD have been the industry standard for the mic but if you look up my card in Google Images it's the blue one!
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
What's wrong with sound integrated on MB.?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I dunno, I've always used cards. I guess I could pull the Audigy out and try the integrated one....
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
You have "Realtek ALC892 codec" chip, same as mine, beats old SBs any day.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
OK. I'll give that a try then. :)
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
OK. So that's better for sure using the Realtek but now that I've got things more squared away I was able to deduce what's going on with the front panel. The input hole is loose or something. I brought up the sound properties dialog and plugged the headphones in but the default green check remained on the speakers. When I wiggled it a bit it jumped back and forth between the speakers and the headphones. Once I got it to stay on the headphones I barely moved the cable and it jumped back to the speakers! :-( Of course iTunes balked at this and refused to go after that began happening. Not sure if there is anything that can be done about the botched front input now. SIGH... always something!
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
Which headphones are those, not for cell phones I hope, a bit different type of connectors on them.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I'm using some in ear types I use with my Mp3 player but they worked a couple of weeks ago in this panel. If there is a different connector I need then let me know - (this has the two black rings) They are Philips. I love them because they are in ear but not those new ones that go all the way in, those make my canals itch like crazy. I HATE over the ear headphones because they all hurt my ears, the cartilage gets sore after about an hour and them make my ears sweaty. So I kinda need in ear but just not all the way in and the Philips are the only ones I've found that are affordable and have good sound.
PS. IF this is not the correct connector then is there a bit I can buy to convert them to the correct input?
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
I asked about them because some smaller device ones like phones can have 3mm instead of 3.5 mm jacks, just a few days ago I run into that trying to use Samsung Galaxy earphones in my tower case and found about difference as 3.5mm are more accepted standard.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Windows 8.1 64 bit
    CyberPower
    Gigabyte X99-UD4-CF
    16 Gigs of DDR3
    on board
    Toshiba 1863GB SATA
    liquid
    MS default
