Good evening to all.
I have an Acer Aspire i7.E1-572 laptop.Windows 8.1
Went to use the sound recorder that is included in the laptop,My granddaughter went to give a song into it and all went to plane,Played back the recording it was just perfect.
Now the only hitch is where does it save the media I looked in all folders but failed to find it.
Can anyone Please help.
Many Thanks.
Intel Core i7-4500U Dual Core (1.8GHz, Intel Turbo Boost up to 3GHz) Processor
6GB
Integrated (Intel HD Graphics)
15.6" (1366 x 768 HD Resolution
1366 x 768
750GB
MSE
Acer Aspire E series Intel Core i7-4500U Dual Core (1.8GHz, Intel Turbo Boost up to 3GHz) Processor
Screen 15.6" (1366 x 768 HD Resolution)*
Operating System Microsoft Windows 8 64-bit
RAM 6GB (DDR3) *
Hard Drive 750GB
Optical Drive DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi)
Graphics Integrated (Intel HD Graphics)
Wireless LAN Wireless (802.11b/g/n Wireless)
N
1 - If you use Metro Apps, it is stored under:
C:\Users\USERNAME\AppData\Local\Packages\Microsoft.WindowsSoundRecorder_8wekyb3d8bbwe\LocalState\Indexed\Recordings
Where USERNAME is your user account
EDIT: You'd need to turn on the "Show hidden files" from the folder options
2 - If you use Windows version, then it will prompt you where you want to store.
6GB
1366 x 768
750GB
MSE
RAM 6GB (DDR3) *
Hard Drive 750GB
N
6GB
1366 x 768
750GB
MSE
RAM 6GB (DDR3) *
Hard Drive 750GB
N
