Audio/Video randomly dies?
    I've had this laptop over a year now, and just recently I've noticed when I leave it on a while and come back, either the audio of the entire laptop will die, or online videos just won't play. After restarting it goes back to normal until a few hours later when it happens again. I'm not sure what to do here. Can anyone help me out?
    You are not alone with this problem, since the last windows 8 update there is sound problems with a lot of PCs. You can try this quick solution here :
    You just need to enter to the Control Panel -> security and System -> System -> Device Manager
    Then look for "sound, video and game controllers" put the cursor over it press right-click and select "scan for hardware changes"
    3 secs after that you will have your sound working again, you gonna need to repeat this procedure every time the sound is gone in your PC and till now it always worked to me.
    This should solve your problem for now, we need to wait for Microsoft's next windows 8 update, it hopefully will fix the problem in a more permanent way.
Video crash, only audio
I honestly don't know what is causing this, so I'll start here. I have a problem that occasionally for seemingly no reason videos will stop working and only have audio. A black screen in browser (Chrome), and green in Windows apps. This started about 2 months ago, the only notable thing being...
Drivers & Hardware
Sound/Audio randomly stops working?
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
Sound dies after playing video file
Hi, I've been having an annoying issue I can't seem resolve ever since 8.1 came out. I've tried reinstalling drivers but that didn't help and I'm really not sure where to go from there. I've never had this issue on any other machine and to be frank, it really pisses me off that the drivers are so...
Audio Randomly Turns off
The title is pretty self-explanatory. Occasionally, my audio will randomly disable itself (as in, the volume doesn't change but the audio is muted). Additionally, whenever my audio turns off, any video or song (as in, youtube videos and songs from iTunes and Zune) slow down dramatically. So, I...
audio randomly stopped working in windows 8.1
so about a month after I bought my computer,all of a sudden there was no audio comming from my headphones or speakers. i do have to say that windows 8 was a bit new for me because i was using windows xp the only way i can get audio now, is by plugging in a usb with bluetooth connection. even HDMI...
video and audio distortion
I'm having difficulty playing some movies on windows media player and vlc player. Some shows will work and some will be very distorted. The picture 22774 and sound is extremely distorted as you can see in the picture. I didn't have a problem with this before but now I keep getting this? Someone...
Best video/audio convertor
I used to use handbrake on a mac but am looking to convert mp4's to wav or mp3, can anyone help me...?
Software and Apps
