Front&Rear Audio jacks not working, can't find a solution!
    Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out.
    I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty much any method and i can find thus far and nothing at all has worked. I'm a huge lover of music, and the is driving me insane!
    Note: The speakers are fine, they work with my iPhone.
    Any help will be greatly appreciated and i pray it be swift!
    San Jose - California
    Right click on the little speaker icon on the taskbar, select playback. Do you have it set to Speakers ?
Mic Jacks not working *MORE DETAILS BELOW*
I'm using a Logitech G230 (Note: I went to a friend's house and tested the mic and headset out before posting and it was a-okay) This problem occurred recently when I came home and Noticed my computer a bit out of place (I'm not sure if it was tipped over or not) I use the front Jack and it...
All rear USB Ports sometimes stop working...
And it happens only when I boot the computer up and find that neither my keyboard or mouse are working then I plug them into front (2) avaialable usb ports and they work fine.... And then If I try to uninstall universal bus controllers by device manager then my keyboard + mouse stops working...
Drivers & Hardware
rear speakers not working
all plugged in new computer drivers up to date set to quadraphonic they were working yesterday but they appear to have stopped on their own. the test speaker option worked at first but now they dont when i click the speaker icon to test on the sound playback options tab the level indicator...
Front Audio panel not working on Windows 8.1
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Audio Front Panel not working
Front panel audio jacks not muting speakers
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
No audio except front speakers (Dell, Realtek Audio)
