Losing audio when plugging in any usb device
    Wondering if anyone can help me solve why my audio goes every time I plug in my mouse or external hard drive into one of the usb ports. The only way I can get audio back is by restarting the computer.
    I'm running Windows 8 on ASUS UX32VD.
    I've gone into Sound settings, Communications tab, and selected Do Nothing. But that's not solved the problem.
    Thanks in advance to any kind soul who can shed some light on this!
    Not a help but similar experience. Plugging in my sony xperia phone to the usb kills my mouse.
    If anyone else has the same problem I found a solution that works for me.
    I uninstalled Microsoft update KB2962407 and the sound seems to be working fine now.
    Have a read of this thread for more info
HD Audio Device conflict
I have Asus Z97M-PLUS as my mobo with Realtek® ALC887. In Device Mgr under Sound there are 2 lines: 1) 'Realtek Definition Audio' ... which is OK 2) 'High Definition Audio Device' is alerted with yellow triangle & exclamation mark. What is that ? Is there some kind of conflict ?
HD Audio Device not working
Hi All, I searched the threads but could not find a solution. My High Definition audio device is not working. This is the error message, This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
Bluetooth Audio Device
After update from win8 to 8.1 all sorts of stuff is going wrong. Inside my device manager my bluetooth audio device has an yellow exclamation mark beside it. Tried to update driver but says it's already updated. Let me know what info you need from me and hopefully someone can help me solve this.
Drivers & Hardware
BSOD when plugging in a USB device.
So i"m having a problem. Every time i plug in a USB device or an external hard drive. Anything trough a usb port my pc BSOD"s. I will give you a copy of an event log so you can tell me what do you think. - System
BSOD Crashes and Debugging
audio device
does window 8 have an audio output device; I wrote before of 2 audio services that say they running but when you hit properties it is stopped and the other is window endpoint. I do not have any audio output . I could be wrong Lorrry
AMD High Definition Audio Device and [..]
Weird issue with AMD High Definition Audio Device and possibly AMD in general. It's not very important if it's only for the HDMI device since I don't even use it lately but I'd like to see if there is a solution. Basically the latest driver (from catalyst package 13.1) is but it won't...
Graphic Cards
Low Audio Device volume (Help please)
I have tried lots of things to try to solve the problem, but to no avail. Please if you know anything that will help solve my problem please let me know. Thank you!:D
