Volume Mixer Problem
    Hello guys,
    So i got a problem on the Volumer Mixer.
    All started yesterday after i decide to install my new speaker... now is giving a headache to fix to the way that was before.
    Basically before i could control all the computer volume but now when i go to volume mixer there is a lot of stuff open and then i need to control each volume for each application...
    I want to be able to remove all applications and be able to put louder my volume with only one slider.
    here is a picture of the problem:
    The Device is my Headset a Logitech G930. when try to turn the volume louder on this slider:
    Doesn't get louder like the headphone used to get.
    Well i hope anyone can help here, thank you very much.
    That's for analog speaker output, you have USB headphones now, different ballgame. In Control Panel > Sound, you should be able to find those headphones and adjust from there. Alternatively, there should be a driver and program for them too, sou you could set them from there.
help i cant find volume mixer / audio mixer in windows 8
I am trying to install pinnacle studio 16 ultimate in windows 8. They say it is compatible however I am not getting any sound in the programme. The helpline says I need to turn on sound for this programme in something called volume mixer or audio mixer. Where and how do I find this in Windows 8. I...
Software and Apps
Line In is missing from Volume mixer after reboot
I have an audio source connected to Line In and I use the volume mixer to un-mute the input when I want to listen to the audio from that source. I recently started having a problem where after re-booting Line In does not show up in my volume mixer and I do not hear audio from the Line In Source...
Volume mixer becomes unresponsive when I change volume
Volume Mixer Frustration
I have a Qosmio X870-BT3G23 laptop with Windows 8.1 installed. When playing a game, I noticed sound volume got quiet. When I alt-tabbed out of game, I noticed volume mixer sliders were not all set the same. I moved them all up to match main Speaker level, but it is frustrating to keep setting them...
Location of volume mixer settings...?
I have an ongoing annoyance, which I've had through all Windows versions from XP or maybe Vista onwards, in that although I can individually set the volume level of each program that makes any sounds, all those volume settings are wiped out and reverted to the much unwanted default level every time...
ok... someone look at the screenshot of the volume mixer and tell me those squares belong....
Volume mixer
Hi all, after so long I've been using Windows 8, I noticed this feature(?) in this OS. See attachment. My question is: Why is every application's volume is half of the device volume? I tried moving the bars of the app's volume to match the device volume, but it will go back to the...
