where is my graphic equaliser for audio playback
    windows 8.1
    i cannot see my graphic equaliser for audio playback - not in the music player but in general.
    example - i am watching something on youtube and want to adjust the audio but within my sound options i dont see graphic equaliser at all .
    i done have a dedicated sound card yet but until i do i need to be able to sort out and adjust audio for things like youtube/twitch/and spotify
    is there a really good free graphic equaliser available to download or even a paid one . i dont know why but i swear my audio was better on windows 7 .
    i also have a xfi mb built into my motherboard i believe as it used to work on windows 7 but since i changed operating systems it has obviously gone .
    where can i download the x-fi mb programme for windows 8.1 ? it is the basic version with just a control panel and built in equaliser
    many thanks
    First, the Xfi MB is a PC vendor supplied product. You didn't list the PC specs, but if it is a Dell, go to the Dell, My Downloads, and you can get it. On another brand I can't say where or if it is available.
    Without the sound enhancement to the PC's on board sound, SOME devices, such as RealTek have an HD Audio Manager that, depending on what the PC vendor has allowed, does offer different EQ's.
    windows 8.1
    sorry my bad ,
    its a Asus rampage 2 extreme mobo with a built in chip which you can see here
    i have windows 8.1 x64 installed
    thanks for your reply
    OK. ASUS needs to be contacted about getting the XF MB software.
    I went to the ASUS link you provided and it shows ADI/Soundmax sound. However, when I went to support and downloads for this model, it has a RealTek driver listed. Different sound chips. ASUS will have to clarify what is actually there.
    I don't know of any add on EQ but there may be one around, that you have to pay to get. Sorry I can't help you further.
Black screen while video playback (Audio only)
Hey guys. I discovered that besides VLC player on my laptop all the other video player are not able to work properly (meaning,, Windows Media Player 12, Cyberlink PowerDVD12 and WMPC are able to play only the audio, but not the video, it's just black screen),, BUT with VLC is no problem playing...
Graphic Cards
Realtek audio, Gigabyte mobo: muffled audio, no mic input
Audio issues (Static + crackling) and high audio latency
After having my motherboard, graphics card and RAM replaced due to a power surge, I have been experiencing high audio latency, along with very poor sound quality which includes static noise, crackling. The sound is similar to that of an untuned radio. The sound...
messed up audio playback/microphone with video recording
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
The audio quality I need for video and game playback.
Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using? The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback....
Split two different audio outputs to playback devices?
Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers. I am wondering if there is audio management software. Similar to how if I am on Skype I can...
Audio Alerts Disrupt Java Audio While Live Streaming
