Solved HDMI No sound
Gurses
Hi, for the first time ever I'm trying to connect my laptop to my TV via a HDMI cable, everything works fine apart from the sound, it's being played via the laptop for some reason.
I went on the sound options on device manager, the "Digital Audio (HDMI)" option says "not plugged in" therefore I can't enable it to play it through the TV. I've also tried to change the projection to "projector only", no luck.
I went onto "device manager" every one of my drivers seem updated, apart from a single one which I don't even think is currently downloaded. I try to use the "update" button however it can't find the driver online. I don't know which driver it is therefore I can't download it manually either.
My laptop is a "HP Pavilion g6" and TV is a Philip, not sure of the exact model however. I've left some screenshots below to help you geniuses with assisting me!
I figured it's a "Realtek" device, but not sure which one :(
Please help!
    Windows 7
Check if you have Intel Chipset Drivers installed.
Open registry and under: HKEY_LOCAL_MACHINE\SOFTWARE\Intel\InfInst
The latest version should be: 10.0.13
If it is missing then download and install the drivers. Intel Chipset Drivers should install any missing drivers for the built in devices on the MB such as USB, HDMI etc... and hopefully the yellow exclamation mark will disappear.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Hi, when I checked it was one version 9 something, I updated it however the missing mark is still there, here's a screenshot:
When I run the Intel driver update utility here's what the results are:
    Windows 7
You might also want to check if you have the latest BIOS firmware.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
It looks too hard to update but I can say that my laptop is always updated when it needs an update. :(
Understood. It's a little scary for most people when dealing with BIOS update. However, we are in the process of eliminating the problem and often the BIOS update is neccessary to correct some of the problems with built in devices.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Do you know a suitable and easy to understand guide you may be able to link me? Thanks for the responses bro.
    Windows 7
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Here's the link to show you step by step what need to be done to update the BIOS:
Updating the BIOS | HP® Support
Don't laugh but I just restarted my laptop and it worked :| Thank you for the help bro!
Hey, good to hear it's working. So you did not restart after updating the Chipset Drivers ?
Yep the driver was at 9 something, updated however I restarted a few hours later therefore I don't know if it was because of the driver or not. No complaining though
    Windows 7
