Changing sound output -different listening positions
    Win 8.1
    Hi all,
    I was wondering if its possible to have a software switch which changes the in-use speakers.
    For example, I'm typing this sat at my desktop. The speakers are optimised for the person in this chair.
    Are there any media players (or other programs) which could switch the speakers over for listening across the room.
    If I could press the button and make (for example) Front right to become 'Room left' and Rear left to become 'Room right' (music being 2.1 channel stereo).
    Is this a thing?
    I guess its similar to multi-room setups.
    Nothing that I know of with a simple "switch" (utility).
    If you want a different speaker system to operate, you would need a "switch box" to be able to manually switch from one speaker system to another. I have that on my PC as I also use it for my recording studio. I have my regular 2.1 computer speakers and I also have Studio Monitor speakers. I have a speaker switch box that I can switch the PC output to either the 2.1 computer speakers or the Studio Monitor speakers.
AMD HDMI Output 'not plugged in', no sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
FIX - AMD HDMI no sound output to monitor speakers
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
No sound on start-up, Win8 needs time to output sound
my sound icon is showing no audio output device is instld
i have a dell inspiron 14z 5423 laptop which supports IDT high defination audio driver . . . when i try to insltal it from the site the box says that " the hardware detected is not supported by this IDT .software package . . the install will be aborted . . .but in the dell site it shows that my...
Drivers & Hardware
Driver working properly but there is no sound output
Problem: My laptop with OS Windows 8 will become no sound frequently. I try to find out the cause, and discover that the device is being used by another application, but I can't find any application using it, here is the screenshot: 47290 47291 Under this situation, when I open Window Media...
No sound when using optical digital output
Onboard Sound: ALC 888s external DAC/amp: Fiio E17 Connection: ALC 888s out----Optical digital cable-----Fiio e17 SPDIF in I do not get sound when I set Realtek Digital Output (Optical) as my playback device. I tested the cable and fiio e17 on my PS3 and it works fine. I tried on windows 8.1...
HDMI Sound output issues
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
