Sound Card not working
    I noticed that my music wasn't playing on itunes and it said that my soundcard was not working properly. When I troubleshoot the 'playing audio', it says that they could not identify the problem. I uninstalled and reinstalled the RealTek HD Audio Driver and still no luck. My computer did run an update before the poblem occured and i'm guessing that's why it happened.If anyone could help it would be greatly appreciated! Thank you!
    It is an hp laptop, Windows 8
    The Product # - C2M44UA#ABA
    Model # - 2000 - 2B29WM
    Edit: It actually started working for a while and then stopped again the next time I opened my computer.
    Go to device manager and check if there is a yellow exclamation mark in there.
Irql_Driver_No_Less_Or_Equal (cmudaxp.sys) -- Sound Card?
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
BSOD Crashes and Debugging
Sound Card not working after Windows 8.1 Windows updates.
Hi, After the latest lot of Windows Updates for 8.1 my Asus Xonar STX no longer works and I get an error message saying "an Asus Xonar STX has been detected but the drivers appear to be corrupt, please try reinstalling them." I have tried uninstalling and reinstalling both the card and...
Sound Card Recommendations
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
No sound on LeadtekTV card on windows 8
Hi all. I have an old TV tuner, Leadtek TV2000XP Deluxe and the WinFast PVR2 tv software. System is Windows 8 Pro. As I said, the card is old and last drivers were for Vista. But those drivers worked perfectly with Windows 7. Now in Windows 8, I instaleed the same drivers and TV Card is working...
Virtual Sound Card?
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
