No sound from speaker/headphones, can't find any errors.
  1. #21
    Perfect: REALTEK, allways install the driver with panel
    For REALTEK, allways install the driver that comes with the panel named "Realtek Sound Manager" (also seen on the Windows Control Panel & Tray Icon Area (orange icon, if visible, after installation) -- otherwise, you'll get a "half-instalation" only).
    Example: Realtek Sound Manager appears, like this
    In other cases, the system SET DIGITAL audio as default, though you had "the speakers" (analogic) set as the current default(!) -- erroneously, some programs assumes(?) that the digital be the default, like Skype can do: So, disable, momentarily, other inputs, verify that the pair [5.1 & speakers] are the actual set, to work fine.
    Good luck y'all
  2. #22
    Found this thread because I paired a set of Moto Surround headphones to my Samsung all-in-one, and the sound was terrible. Played with the EQ settings, etc. and from youtube videos to realplayer, nothing sounded 'right'. I plugged in a wired pair into the bose 'hub' that my bose speakers have (it's a on/off switch and rotary volume with passthru headphone jack) and now my external speakers no longer work!
    all my realtek drivers seem to have disappeared and there's a BT item in my device manager with a yellow exclamation mark now.
    Hope someone can help. I tried unplugging the AUX out from the computer and then back in, but this isn't usb so windows sort of recognizes something was unplugged and back in but it's not reinstalling drivers. And now my sound control panel has NOTHING in it and windows says no playback device is installed.
Page 3 of 3 FirstFirst 123
Sony External bluetooth speaker not playing sound
So, i got a speaker Sony rdp-x200ipn. I have an Acer Aspire E17 I can connect my speaker to my laptop via bluetooth fine, when it's connected i can test the speaker and it makes the beep sound. When i start itunes, my speaker plays the sound fine, but when i search for example a youtube video...
How do you enable speaker output while headphones are on?
...for SELECT programs? For example, I like to game with headphones on, I listen to music with headphones on and more. I don't like to unplug them every time I'm done, that's too confusing and more importantly, I FORGET ALL THE TIME. So, if anyone could kindly help me find a way to play my "Free...
New brand USB speakers. sound from one speaker only on USB
Yesterday, I bought a pair of Samson Studio GT studio monitors. which connect to my computer via USB. However, I'm only getting sound out of one monitor/speaker, that would be the right side with the power cable. I've checked the speaker wires and made sure they were hooked up correctly for...
HP Pavilion dv6-6110us No sound without Headphones
HP Pavilion dv6-6110us Entertainment Notebook PC laptop running windows 8 upgraded alright. Left the computer on overnight now the sound will not play through the computer speakers unless something is plugged into the headphone or microphone jack. But will play through external speakers... but not...
Win8 64 bit no sound on headphones jack
Hello, I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu. I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me...
No sound with headphones?
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
No sound thru headphones
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
