No sound in subwoofer when using mediamonkey, vlc, netflix
    I setup a subwoofer to run from the pc from the orange hole to the sub via a 3.5mm to rca cable. I can't get it to play sound from any other program other than pandora, battlefield and youtube. VLC, netflix, mediamonkey all ignore the sub and don't use it. My speakers are connected to the computer through the green hole to the t amp (no sub out on the amp). I tried downloading my audio drivers but I get an error saying "can't find hd audio device". My motherboard is a gigabyte gaz77xd3h running on the latest f18i bios. When i was on 7 the drivers worked fine, but on 8.1 they don't install. I've tried the original version that came with the mobo and the most recent one and both don't work.
    You apparently are trying to circumvent the speaker setup with the separate bass speaker. Audio systems are set up to feed audio based on how you have your speakers set up (e.g. 2.1 stereo , 5.1, etc). As you apparently have a 2.1 (or 2.0) speakers connected to the green speaker jack, what do you have the speaker type set as?
    In multiple speaker setups such as a 4.1, 5.1, 7.1, etc although there are separate connections to the speaker jacks, its really controlled internally in the speaker system, not separate like you want to do it. What you are doing may work with some functions but its not the correct/legitimate setup.
No sound from subwoofer in Windows 8.1!
Hello everyone, I've just got my new PC and I've got a problem with my new audio system.. I have a 2.1 Speaker system and I don't hear any sound from my subwoofer. I've looked for the problem on Google, I tried to update my drivers, I tried almost everything. A little help would be welcome, thank...
Speaker Settings Subwoofer Crossover Not Working
I run a 7.0 speaker system connected in multi-channel analogue mode to my Creative X-Fi Titanium. I set my speaker settings on Windows 8.1 disabling the subwoofer and checking the full-range speakers checkbox to allow the low frequencies to be handled by my satellite speakers. I've made no...
Can't Drag & Drop Mp3 files in Audition 1.5 & Mediamonkey
I just built a new Windows 8.1 64 bit with Asrock Haswell Extreme 11 ac motherboard. Using old copy of Audition 1.5 and Newest copy of Mediamonkey 4.1. I can't drag and drop mp3's into the programs. The only way I can get them in is through File/Open. I know that the Audition is very old, but I...
asus external subwoofer
hi guys! i just want to know if the asus sonic master external subwoofer is compatible with other laptop lie lenovo g580? because my friend gave me this subwoofer and connect it to my lenovo laptop.but the sound coming out is very there anything i can do? please help guys..thanks in...
Subwoofer wont please
Hello, I m new to this forum so excuse me is there is a link similar someplace else. my computer is connected to my samsung tv and there is a yamaha rx-v375 receiver in between the computer and the when i play a video/music/games off my ps3 which is connected to the same setup, it works...
Windows 8 makes a sound and pauses netflix.
Windows 8 makes a three tone sound and netflix pauses. I suspect it also crashes my games when it says it. I have tried replacing my RAM, but it still does it. I have never had BSOD and windows does not stall or crash in any way. I reinstalled from windows 7 to windows 8 about a week...
ASUS Sonicmaster Subwoofer not working (not detected ?)
Hi, I just bought a brand new ASUS N series today, and it came with a sonicmaster subwoofer, which unfortunately doesn't work. Whatever I play it comes out of the regular computer speakers, and I've made sure all the time that the sub was plugged correctly and at the right place (subwoofer jack,...
