Solved Can't run sound-using programs
maxiking
Can't run programs that use sound
Hello,
ever since I updated to windows 8.1 on my laptop, every once in a while, when i start it up, I just can't run anything that uses sound.
- What is effected? Apparently every programm (Games, Windows Media Player, Audacity) that uses sound, just doesn't start, or, crashes when i start it up. But games and other programms, that have no sound for any reason run just fine. I can use Chrome with no proplems, but when i watch a video, or go to any other site that requires sound, it just doesn't load, or the area that uses the plugin doesn't work (so e.g. i get a black youtube video area)
- When does it happen? Recently the proplem appeared sometimes when i started my laptop. Rebooting it usually fixed the problem. But today when i started it up, it just didn't work, nor could i fix it by restarting.
I am using a MSI GE60 laptop, to which i have a logitech mouse and headset attached, with the required software installed (which crashes when i try to make a sound check). But even when i disconnect the headset pre or post starting the laptop, there's no difference, and even tried reinstalling the Logitech Gaming Software, therefor I'm assuming that's not the problem.
I would be very thankful for any advice on how to fix the problem.
Thank you,
Maxi
Are your Audio device drivers up to date, go to the manufacturers web site to verify.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
Welcome to the Forums.
One "quick fix" support trick that works maybe half the time or better, is boot into Safe Mode. Then open Device Manager and delete the device with the problem. Reboot. On start Windows will find the hardware and reload the drivers. It doesn't take long to try it and as I noted, in my experience the success rate is fairly high for these types of issues.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
Glad it worked for you. :)
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
