Input from External Microphone only mono
    I only just bought a new computer with Windows 8.1 on it. (SO not impressed with this OS.) Anyway, I'm trying to set up all my externals. I have an external microphone I use through a Tascam US-200 audio interface. It has the ability to record in stereo and I have done so for some time using Audacity on my old computer running Windows 7 with no problems.
    I checked that the Tascam system has been tested with Windows 8. No problems there. I installed the drivers and audacity and set everything up. However, I'm still only getting mono sound instead of stereo when I attempt to record. I've double checked that the Default Format for the input device is set to 2 channel, 16 bit, 441000 Hz and that Audacity is set to take in a stereo input. No joy. I can record sound but only in mono.
    Any ideas?
    P.S. After repeated attempts I CAN get the system to recognise the stereo input... for less than a second when first turned on. Something is getting through but for some reason it just doesn't keep.
    I have a recording studio (I use Sonar X3).
    Do you have Windows 8.1 specific drivers? When 8.1 came out many recording audio devices, including my Roland Octa-Capture required Windows 8.1 specific drivers to properly work.
    From the recording forums I visit, this was a major issue with many devices. They worked properly with Windows 8, but did not with 8.1.
External microphone not detected, tried everything
Hello, i'm using a Siberia V2 headset. Here is my laptop : Asus ROG G741JM-T4065H I'm using this splitter : Headset adapter for headsets with separate headphone / microphone plugs - 3.5mm 4 position to 2x 3 position 3.5mm M/F: Electronics My headset is in the...
USB CABLE, Monitor Input, PC input?
What can be done with USB Cable regarding PC? Is it worth it? I use a Dual monitor cabe, one end plugs into The Display shared Vga Connection. The other 2 allow me to have up to a total of 3 Displays. Is there products that allow more than the standard 2 outputs? Example 4? Thank you
Treat mouse input as touch input
Hi, Happy new user of my first Windows 8 device (Dell XPS 12 i7 running Windows 8.1 Pro). I like the touch input when it is flat in tablet mode, but when I plug a USB mouse into it when I am at my desk, I want the mouse inputs to be treated exactly like finger inputs on the touch screen. For...
Drivers & Hardware
External Microphone Currently not Available
I have two laptops running windows 8, Asus AO756-2626 and HP dm4-3099se. Internal mic works on both. I have two computer mics and one professional type that needs an adapter for the jack. When I insert either mics, nothing happens on either laptops. The external mic in the sound settings is grayed...
Not hearing my voice (microphone input)
Hi, I wonder if there's a way to make my own voice audible in the speakers/headphones when using a microphone? I also have RealTek HD Audiomanager installed, since I have an ASUS board. Could this be done in Windows?
Laptop with HDMI Input, but no program to watch the Input
So my Laptop does accept HDMI as Input to. But i dont know about any program, that can watch what is being put in. Does someone know one?
Software and Apps
8 microphone
microphone not working
