Hi,
So instead of explaining what I'm looking at right now I'll post a picture here:
So as you can see that bar there is putting my volume automatically up to 100% every single time I touch it. Also, recently this has made the computer unable to drag the top or side or have any Windows 8 features available this includes both Windows buttons on my keyboard. I have tried cleaning my keyboard as that seemed to work last time on fixing this problem for maybe a month, however it worked for only an hour this time. It also seems note worthy that I cannot capitalize these letters at all: z x c v m , . \ and then I can't capitalize certain letters with certain shift bars so I can capitalize s with my left shift but not my right this happens with many other letters too but the ones I listed above cannot be capitalized at all.
If you need any more info I can give it to you. mainly (could not capitalize the m and any other letters that I put that are capitalized and said could not be I Google searched for the capital version of it) what I'm asking is how to disable this bar I've searched for answers and even reinstalled my audio as some websites said to do. Is this a problem with my keyboard I'm not too sure. It's a AzzA Gaming keyboard so yeah and it's mechanical keyboard. The computer that I'm using is a custom one I ordered online but if you need I could list the specs. I also run with Realtek and nvidia audio.
Thanks for any and all help. Hopefully we can fix this problem as it makes things nearly impossible to do on the computer.
- Windows 8.1
- Computer type
- PC/Desktop
- Memory
- 1T
