Speaker Settings Subwoofer Crossover Not Working
    Windows 8 Pro x64
    I run a 7.0 speaker system connected in multi-channel analogue mode to my Creative X-Fi Titanium.
    I set my speaker settings on Windows 8.1 disabling the subwoofer and checking the full-range speakers checkbox to allow the low frequencies to be handled by my satellite speakers.
    I've made no changes to the settings and yet I suddenly experienced a decrease in bass after a system restart.
    When I checked the speaker settings I noticed that checking/unchecking the full-ranged speakers and subwoofer checkboxes no longer made any difference. i.e. the signal still gets passed to the centre/subwoofer port on the soundcard.
    Clicking on the subwoofer on the window, I can only hear sounds from my front left/right speakers. Previously, unchecking the subwoofer checkbox sends the low frequencies to the available full-range speakers.
    I have tried using an optical connection on Dolby Digital and it gives the same problem.
    I am running the latest driver version available.
    Any suggestions?
    That is not normally how a 7.1 system is connected/setup up. But if it works (worked) for you then I can't argue. However, what bass you are getting is controlled by the amplifier in the speaker system. If there were a change, something in the speaker system is the problem and probably not the PC.
Surround working, but no Speaker Fill option - Realtek
Hello, So I've recently built my own PC and now I'm trying to use 5.1 surround with a set of speakers I have lying around. 5.1 is working in applications that specifically support it, such as XMBC, where I can enable support in the settings. However, other applications do not play surround...
No sound from subwoofer in Windows 8.1!
Hello everyone, I've just got my new PC and I've got a problem with my new audio system.. I have a 2.1 Speaker system and I don't hear any sound from my subwoofer. I've looked for the problem on Google, I tried to update my drivers, I tried almost everything. A little help would be welcome, thank...
Change Pc Settings Not working
Hey, I have recently upgraded to win8.1.I not able to change my pc settings as it is not working. I tried this tutorial but its showing this message. Fix: Broken Change PC Settings link after upgrading to Windows 8.1 ...
asus external subwoofer
hi guys! i just want to know if the asus sonic master external subwoofer is compatible with other laptop lie lenovo g580? because my friend gave me this subwoofer and connect it to my lenovo laptop.but the sound coming out is very there anything i can do? please help guys..thanks in...
Subwoofer wont please
Hello, I m new to this forum so excuse me is there is a link similar someplace else. my computer is connected to my samsung tv and there is a yamaha rx-v375 receiver in between the computer and the when i play a video/music/games off my ps3 which is connected to the same setup, it works...
ASUS Sonicmaster Subwoofer not working (not detected ?)
Hi, I just bought a brand new ASUS N series today, and it came with a sonicmaster subwoofer, which unfortunately doesn't work. Whatever I play it comes out of the regular computer speakers, and I've made sure all the time that the sub was plugged correctly and at the right place (subwoofer jack,...
I searched everywhere with the same problem but can't find any, so posting it here: (sorry if i posted it in a different topic!) i've been having this weird problem since i installed windows 8 on my system. at first i thought it is nothing, but after reading forums i found out there is some...
