The audio quality I need for video and game playback.
    Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using?
    The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback.
    So can anyone recommend me a level I should use that will be the most appropriate for my earphones?
    Please respond as soon as possible.
    Thank you in advance.
    -Arcturus Fyr
    That's very dificult to say, it depends on to many factors. From how sensitive your ears are to how detailed sound in games is. It could be different in different games. Best thing is to keep lowering until it's unsatisfactory for you. I don't think it matters a lot to game's performance, if that's what concerns you. Those settings for sound are all "up to", if something is recorded in low format, no settings in reproduction are going to make it better.
    Thank you for responding, that's actually quite refreshing to hear. To be honest, yes. I was indeed hoping to eke out some performance gain by doing this, it seems some particular games of mine just have issues with the certain sound settings.
    I hoped there would be some kind of stability and/or performance gain by lowering the default sound setting that I had, but I see it's not that simple.
    Thanks for clearing some of that confusion for me.
    -Arcturus fyr
Black screen while video playback (Audio only)
Hey guys. I discovered that besides VLC player on my laptop all the other video player are not able to work properly (meaning,, Windows Media Player 12, Cyberlink PowerDVD12 and WMPC are able to play only the audio, but not the video, it's just black screen),, BUT with VLC is no problem playing...
Graphic Cards
New Skype Version Improves Audio Quality
Windows 8 News
messed up audio playback/microphone with video recording
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
Best video to high quality audio converter
I have alot of mp4 music videos that I would like to convert to wav or flac. Can anyone recommend the best software for doing this on windows 8?
Software and Apps
HDMI on TV no audio, poor quality image
I just bought a new laptop and tried the HDMI, but there is no audio and the image is poor. It's an Asus X501A with Pentium 2020M Ivy Bridge and Intel HD Graphics. I tried changing the output resolution, to tweak the audio properties, etc. No success. Any idea?
Poor Quality Audio in MP4 Video's
Since installing Windows 8, the audio quality in any MP4 files is distorted and echoes. This happens regardless of what player I use to view them (You Tube, iTunes, Media Player). If I play a professional video in You Tube it is OK. All other types of video are fine and all other sound output...
Video App crashes after 10 seconds of video playback
Hello All, I just installed The Windows 8 Release Preview using a bootable USB dual boot. I'm not able to play any format of my videos on my windows 8 rp... When I open a video in video app or the windows media player it doesn't show the video and closes or hangs after 10 seconds of playback (No...
Software and Apps
