Solved The audio quality I need for video and game playback.
Arcturus Fyr
Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using?
The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback.
So can anyone recommend me a level I should use that will be the most appropriate for my earphones?
Please respond as soon as possible.
Thank you in advance.
-Arcturus Fyr
    Sager NP9377 (Clevo P377 SM-A)
    Intel i7 4810MQ
    MXM Sager
    Dual-Channel 16gb 1600mhz 2x8 (Stock)
    Nvidia GeForce GTX 980m SLI gddr5 w/8gb Vram dedicated
    Sound Blaster XFi-3
    17'inch Single-Monitor Display
    1920x1080p
    (Stock) x3 1 Terabyte 7200rpm SATA III
    330 Watts
    Stock Matte Finish Chassis
    Twin Fans and Copper Cooling System w/ Targus Chill Hub cooling pad
    Logitech
    300-360kb
    Malwarebytes Anti-Malware - Free Edition w/ Eset Nod 32 v.4
    Still playing Oblivion, are you?
That's very dificult to say, it depends on to many factors. From how sensitive your ears are to how detailed sound in games is. It could be different in different games. Best thing is to keep lowering until it's unsatisfactory for you. I don't think it matters a lot to game's performance, if that's what concerns you. Those settings for sound are all "up to", if something is recorded in low format, no settings in reproduction are going to make it better.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Thank you for responding, that's actually quite refreshing to hear. To be honest, yes. I was indeed hoping to eke out some performance gain by doing this, it seems some particular games of mine just have issues with the certain sound settings.
I hoped there would be some kind of stability and/or performance gain by lowering the default sound setting that I had, but I see it's not that simple.
Thanks for clearing some of that confusion for me.
-Arcturus fyr
    Intel i7 4810MQ
    MXM Sager
    Sound Blaster XFi-3
    1920x1080p
    330 Watts
    Logitech
    300-360kb
