2 usb sound bars only one selected as default
    I have 2 USB sound bars connected to usb ports on my pc. Under sound settings I can only select one of the sound bars as my default speakers. Is there some way to select the second as well?
    Windows, as designed, will only allow one "default" audio playback device. There may be some 3rd party software that will allow more than one but I don't know of any. This is not just a Windows 8 issue, it is the same in Vista and Windows 7.
    There may be some external hub that will allow both to be used? but again, I'm not aware of that.
Boosting sound over the default maximum
Hi, is there any wayto boost the sound volume in Windows 8 over the default maximum? I'm open tothird-party programs to help with this also.
default lock screen imageflashes before my selected image
This is really annoying, but I set my lock screen image as my own image and every time I boot up my computer or log in/log out, the default lock screen image flashes right before my image. It is a real eye-sore. I found the image in the windows folders, it is: C:\Windows\Web\Screen\img100.jpg....
sound bars
Hi could someone give me a bit of advice please i have a 60 inch smart tv samsung the sound is not as clear as i would like so i am thinking of a sound bar i have no idea where to start .ie the size .has it got to match the size of the tv has it got to be the same make as the tv ??? any advice...
Print selected text
Just starting to use my new windows 8 getting frustrated!! How can I print selected text in a email or web page without printing the complete email or web page?? When I select the text and select devices and printer (Canon Pixma MX512) I don't get the option of 'print selection' Can anyone Help...
Random Beeping (default Asterisk sound)
Hello, I am getting a random notification sound but no notifications are appearing in Windows 8. I have isolated it to be the default asterisk sound but nothing is plugged into my computer, not even the power cord, and I will still get the random sound. Any ideas? Thanks!
Why don't windows go on top of others when selected from task bar?
Here is another annoying feature I am noticing in windows 8. If I am browsing the net in Firefox, and I want to pull up another window which I select like normal from the task bar. It does not pull up. All too often, I am finding that I have to manually minimize my active window in order to pull...
Cannot install on selected partition
When I try to select the partition on which I want to install the WCP, I get the following error: Windows cannot be installed to this hard disk space. The partition contains one or more dynamic volumes that are not supported for installation Below is a screen capture of Partition Manager...
Installation & Setup
