Microphone levels too high and auto resets
    I am using a USB headset with a microphone (Logitech G35). As the title suggests, my microphone levels are too high. My microphone picks up almost everything, especially keyboard- and mouseclicks which people have complained about. Whenever I try to adjust the microphone levels to something lower, for example 18dB instead of 24dB, it will reset back to 24dB almost as soon as I start to speak. I have tried to change the levels both in Windows Sound Settings and in the driver for the headset. I have tried multiple dB values, not only the one in my example.
    I am using Windows 8.1.
    Anyone knows what is causing this and a possible fix?
    window 8
    had the same issue but i did change my headset as i was looking all over internet for solution but cant get it sorted, there must be some solution for it please post back so i can use my old one...
High RAM Usage (Spotify high)
First off I have 8GB of RAM, and I get notifications all the time that my RAM is high, and it wants to close programs. The main program that worries me the most is Spotify is using 900MB of RAM when playing and 500MB when not playing. Why is this so high? The games I play are not even that high....
Performance & Maintenance
Mouse Resets On Reboot
Every single time I reboot my system my mouse fails to register in the system. I have to physically unplug it and plug it back in for Windows 8.1 to register it. Once I do that I have literally no issues at all..... Does anyone know how to fix this so it doesn't happen every single time I reboot?...
Drivers & Hardware
Windows 8.1 resets my DNS settings to auto
I don't want to use the DNS servers of my ISP and I don't know how many times I changed over to third party DNS servers now. But 2 weeks later when it occurs to me to check, they are almost always back to Auto, i.e. the ISPs. Why does this happen and how can I prevent it?
Network & Sharing
Desktop Wallpaper Resets
Hello, I'm sorry if this has been covered already but I was unable to find a solution. I am running multiple Windows 8.1 Pro x64 machines but one has an odd issue. It resets the desktop wallpaper for all accounts after the user logs off. When I log back in I get the solid color that was selected...
finding ink levels in windows 8
Just recently upgraded to W8 from XP.. what a learning experience.. Im still Ive googled and cant seem to figure out how to have my ink levels show when Im printing. Im using the same printer, HP.. and they used to show up on XP. or even if I could find the level..period.. Ive...
Drivers & Hardware
Hidden files - auto disable, restore auto enable?!
Hello, I use Windows 8 Pro and I have very strange problem. I enabled display hidden and system files, but system auto-disable its... I make it about three times, always with the same result. I don't know what causes this problem, I can't reproduce its (it isn't after reboot). Also I have...
Right clicking resets desktop
Hello Everyone, I recently upgraded to windows 8 x86, and yesterday I noticed an issue that is annoying the hell out of me. Whenever I right click anywhere on the desktop or in a folder, everything resets. Like everything on screen dissapears and returns to clean desktop. Problem is not in metro,...
