LatencyMon high latency sound card clipping.
    windows 8.1
    Hello, I tried so many things, running out of idea. Hope someone can assist.
    Updated all drivers, realtek, nvidia, amd chipset and bios. Remove everything from USB post and booted without services, disabled network drivers.
    When I uninstall the nvidia drivers I dont get that much latency, I do a clean install and using different drivers and it always comes back. I read on this thread that its some interfering with the drivers.
    My irq's seem strange the Microsoft acpi compliant system has 511 entry's is the normal?
    Windows 8.1 all updated.
    Memory (RAM) 16281 MB
    CPU Info AMD FX(tm)-8350 Eight-Core Processor
    Sound Card: Speakers (M-Audio Fast Track Pr | S/PDIF (M-Audio Fast Track Pro) | Line 1/2 (M-Audio Fast Track Pr | Realtek Digital Output (Realtek | Realtek Digital Output(Optical) |
    Display Adapters: NVIDIA GeForce GTX 760
    Network Adapters: Realtek PCIe GBE Family Controller
    Hard Disks C: 223.2GB | D: 1862.9GB
    Motherboard * ASUSTeK COMPUTER INC. M5A97 R2.0
    Click image for larger versionClick image for larger version
    ____________________________________________________________________________________________________ _____
    Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
    Highest ISR routine execution time (Ás): 1848.831603
    Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
    Highest reported total ISR routine time (%): 0.089085
    Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
    Total time spent in ISRs (%) 0.152184
    ISR count (execution time <250 Ás): 291126
    ISR count (execution time 250-500 Ás): 0
    ISR count (execution time 500-999 Ás): 145
    ISR count (execution time 1000-1999 Ás): 12
    ISR count (execution time 2000-3999 Ás): 0
    ISR count (execution time >=4000 Ás): 0
    DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
    Highest DPC routine execution time (Ás): 2571.252826
    Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 337.50 , NVIDIA Corporation
    Highest reported total DPC routine time (%): 0.946156
    Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
    Total time spent in DPCs (%) 1.910671
    DPC count (execution time <250 Ás): 2020722
    DPC count (execution time 250-500 Ás): 0
    DPC count (execution time 500-999 Ás): 133
    DPC count (execution time 1000-1999 Ás): 6
    DPC count (execution time 2000-3999 Ás): 1
    DPC count (execution time >=4000 Ás): 0
    Thanks, if you need any other info let me know
    Wynnum Australia
    Did it change with later drivers now, or is it still the same, especially Realtek / NVIDIA ? Tried an older Flash Player Version like 11.6 or the latest Beta ?
    Try a different NVIDIA-Driver-Branch (the first 3 numbers of the driver version).
    Windows 32 or 64bit ?
    I have a recording studio (Sonar X3). I have an MAudio Fastrack Ultra 8R and do not have any sound or latency problems. I have the latest drivers, from Avid. required for Windows 8.1. I also have a Roland Octa-Capture with Win 8.1 drivers and no problems.
    I notice, in the screenshot list there is a "High Definition Audio Controller listed. That is usually a Windows installed generic, basic function, sound driver. If you have the correct sound drivers, you should not have the High Definition Audio Controller.
    What sound is actually clipping? The MAudio or the RealTek?
Windows 8.1 High DPC Latency,(annoying static sound)-Help.
Hello everybody. Before I start I just wanted to say , sorry for the bad english . So , I have read allot of forums lately , and I found out that windows 8 and windows 8.1 weakness is its latency. For me this proplem accoured like 2 months ago (before it didn't happend) , and yes I have messed...
Performance & Maintenance
Audio Clipping/Laggy PC performance [high DPC]
To whoever can help me, This issue has started about 2 weeks ago, after I installed new drivers (don't remember which specific one) I started to notice very minor things, like slight overheating on very basic tasks, clipping sounds on simple events like changing rooms in team speak. The issue...
dpc latency high as hell
so i decided to download 2 dpc latency checkers, one said everything was fine the other was dangerously high i then tried having them open with aida64 and stresstesting everything, my entire pc started lagging and the latencymon didnt go up much but the dpc latency cheker spiked a bit higher, but...
DPC Latency pretty high with spikes. Need help
Hello there! As I was having problems regarding stuttering with Battlefield 4 since I started playing it, I decided to run DPC Latency Checker and see if it helps me find the culprits. What I found was pretty weird. The latency was at 1000us with occasional red spikes that are more present during...
another sound crackling and skipping problem ! latencymon
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
High latency when WLAN is on
Hey folks :) I've run into a strange something, which I can't find any explanation for. Whenever I turn on WLAN in my router, the whole network suffers from an incredible latency. No online game is playable, but the download speed itself is not being touched (i.e. fullspeed) and websites load...
Network & Sharing
Why is the DPC latency high on Windows 8?
I cannot recall what it was in Windows 7 exactly, but it was much less than 500us. In Windows 8, it never drops below 1000us. I measured the DPC Latency using the DPC Latency Checker. Any idea why this is? Immature drivers? (Specs in the sig btw) 7761 This is also on the *leaked*...
