Tried a search here but found nothing.
No idea if this is sw or hw.
My audio has worked well since buying my PC (months). Audio on YouTube worked. Audio on MP3s worked.
A few weeks ago I lost all audio. The speaker ivon in the task tray has an 'x' over it. When I swlwxct "troubleshoot,' I get a 'peripheral is not plugged in' response. It is plugged in. I can take the audio cables (cords?) out of the W8 PC and put them in a Vista PC. Audio works perfectly, so I presume the cables are good, the speakers are good.
How do I determine if this is a hw or sw problem?
- Windows 8
- Computer type
- PC/Desktop
- System Manufacturer/Model
- HP
