window 8.1 pro sterio option hedden
    In the Sound/Recording section, RIGHT click in a blank spot and then LEFT click Show Disabled and Disconnected devices. If your system has the Stereo Mix capability it will now be displayed and you can enable it and make it the default recording device.
    Please fill in the "My System Specs". It helps us to help you.
    Click image for larger version all try faild
    I stated the RECORDING section, not the Playback section.
Window doesn't open full screen when hover over IE window
I have a Lenovo N580 laptop. Last week, I had to do a factory reset (with help from Lenovo Tech Support) because of compatibility problems with new software from my employer and windows 8.1 which is actually worse than windows 8. The compatibility problems caused my screen to go black. When...
Troubleshoot Option Under Advanced Startup Option Missing
The Troubleshoot icon that should be under the 'Advanced Startup' Option is missing. System is a new Dell Latitude 10 ST2 Tablet running Windows 8. Have access to 9 other identical tablets, all configured the same and they all have the Troubleshoot Option. Have tried multiple methods of getting...
Performance & Maintenance
Window 8 saying failure configuring window features
My window 8 ultra books has been showing faluire configuring window features for nearly hours and I can't swipe or do anything with it, this happened after the window updates happened, I don't know what do any more, I switched it off and then turned it on, but it's still ones back faluire...
Windows Updates & Activation
Will window 8 automatically change to another window editi
Hello all, I would like to ask some information about8, previously I installed Windows 8 Developer , after sometime (I am not pretty sure how long after installation) the window was automatically degrade to window 7 if I am not mistaken. Would Windows server 8 beta and Windows 8 Beta...
Installation & Setup
Enabling "Startup Apps" option in the CACS window
Hi I have Windows 8.1 Update Enterprise 64-bit. I noticed that, in the "Change Action Center settings" window, the "Startup Apps" option is disabled. How come? How do I enable it? What is the purpose of this option?Thanks Bye
Window 8 Build 9200 RTM After Window Update Some Icon Missing
Hi , My Window 8 automatically Window Update and now some of the icon missing :huh: Anyone encounter this and possible to fix this ?
