Problem with sound settings
    So i just changed my sound settings(i dont know how) And now it is so.
    I have headphones as a laptop normal speakers(usb headphones) and when i unplug them i dont hear anything. If i plug my speaker system to headphone jack the speakers doesnt work. so can someone help me getting my settings correct?
    In the Desktop view (press Windows key and D at the same time), if you don't have a speaker icon at the bottom near the clock, search for "turn system icons on or off". Next to the Volume icon, set the Behavior to On, and click OK. Now it should appear in the lower right corner.
    1. Right-click on the speaker icon and choose Playback Devices.
    2. Click on Speakers, right-click and set to Default Device.
    3. Click on Properties and then on the Levels tab. Make sure the speaker icon doesn't have a red circle in it. If it does, click on it to get rid of the red.
    4. Finally, adjust the Speakers/Headphone slider to the right, maybe to around 85.
    That should solve your problem.
Settings>change pc settings problem
Sound Problem
Hey Guys So i have an Asus laptop running on windows 8 pro. From the past 3 days, whenever I put my laptop on hibernation and switch it back on, the speaker doesnt seem to be working. I am not able to hear anything at all even if the volume is in max. The only go around is to restart the laptop...
Toshiba Laptop with Windows 8.1 won't save sound settings
I have a Toshiba Satellite C55Dt-A5305 with Windows 8.1. The Device Manager only tells me "AMD High Definition Audio Device" and "Realtek High Definition Audio". I've tried updating the drivers, and Windows says they are already the latest ones. The problem that I'm having is the sound is extremely...
PC settings problem
Hello Friends, I have a serious problem in my lap. cpould anyone help me out? My problem is "I have been using windows 8 licensed for past 3-4 months and it was working well.Now I uninstalled one windows update (microsoft redistributable x64) and from then on my problem starts. I cant open PC...
Change sound settings directly in the registry
Hi, I was wondering if it would be possible to either change the speaker settings (switch between stereo, 5.1 etc.) or, preferably, sound balance directly in the registry. Until now, I've only been able to find the key for the speaker settings: However, the changes only go into effect for...
where are the sound settings/audio options???
Just installed Windows 8 and cannot find the sound settings/audio options ANYWHERE. Please help!
