Annoying sound pannel popup
Youss
Hi, anyone having this problem ?
Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :(
Is there a solution please ?
    Windows 8 CP
You need to click away from it to remove that. Alternatively you may need to do a windows update or restart yoru computer. If that doesn't work I can suggest you contact the helpdesk at Contact Us
