rear speakers not working
ChiselChin
all plugged in
new computer
drivers up to date
set to quadraphonic
they were working yesterday but they appear to have stopped on their own.
the test speaker option worked at first but now they dont
when i click the speaker icon to test on the sound playback options tab the level indicator shows green as though they are working but there is no sound coming out of the rear speakers
is there some extra setting im missing?
Double check the audio cables going from the PC to the speaker central amp. Also check that they are set to quadraphonic in control panel > sound. Select speakers from the list and click Configure. It's the same panel shown on the left in your screen shoot.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
it seemed to be a realtek setting. when i unplugged and then plugged the speaker back in a second list of check boxes appeared and i tried checking off rear speaker out they came back on. i could have sworn i already had this checked off but some other setting i messed with must have changed it.
Stuff like that happens sometimes. Windows can switch it to just the two and so can the RealTek software. It never hurts to check both places. You got it working so all is good, for now. ;)
    Asus
    Thermaltake TR 620
    Stock heatsink fan
now it seems like only background noise is coming out of the second set of speakers. is there a way to make all speakers play the same sound? i already tried toggling the speaker fill option on and off and that didnt fix it. only the test option seems to make any significant noise come out of these speakers.
Speaker fill is how I did it I think. One of my speakers died so I'm back to just stereo.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Try setting to 5.1 or.7.1 .some streams can't differentiate good enough. I technically have quad ( 2 times stereo but with woofers incorporated in each set ) and some movies used to play only background sounds on one set (like music and sound effects) and front only speech until set to 7.1. Speakers not plugged in will be grayed out.
Surround Speakers set to On.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
still having problems with this
there is some sound coming out but only on certain music and its echoed and delayed
there are no "effects" on except for speaker fill. it sounds like background stuff and i want all speakers having the same sound
now i am also having problems opening the realtek audio manager, i cant figure out how to open it.
If you are hell bent to have rear speakers running too and don't care about separate controls for them, you can use an audio splitter " http://www.radioshack.com/product/index.jsp?productId=2272476" like this as a stop gap measure. It will give you exactly same sound front and back.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
if im watching netflix or any other web based video site only one set of speakers will work.
this is the absolute worst version of windows ever and i have used every one.
now i have to go to radio shack and buy extra pieces? mmm no thanks i think next time ill be buying a macintosh
ChiselChin, I do not think it Is the OS. Try uninstalling all sound drivers. Reboot then re install the realtec drives. Once again unplug then replug all speakers in
    W10 Pro X64
    Dude
    Intel(R) Core(TM) i5-3570K CPU OC@ 4.5 GHZ Turbo
    MSI Z77MA-G45 (MS-7759)
    8.00 GB DDR3 1600Mhz
    PNY GTX 760
    Realtek High Definition
    Dell S23O9W, HP L1710
    DELL-1920 x 1080 HP-1280 x1024
    Crucial m4 256 SSD WD 7200RPM 500GB
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    MSI DS100 Interceptor
    50 down 5 up
    Chrome, IE 11
    Logitech X-620 Speakers
the computer is not even a month old i shouldnt need to reinstall anything
Nothing to do with how old computer is but how it's set up. Not much to do with OS either, player, codecs and video stream are important here. Watching HD programs on IPTV I don't get all the speakers from different channels either.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Clean install of drivers can do wonders. My 5.1 sound was not working. Did what I said and it works. Forgot to say, reboot prior to reinstalling. Then reboot again after installing.
Edit again
Use the realtec driver from the MSI site for your system
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Edit again
this did nothing
I have to use an older driver on my system or I lose the sound effects tab. Maybe an older driver might help you too.
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Do you have any other sound software add ons installed, like sound blaster by chance?
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
