Hello all
basically I have set all options to say don't do anything when I close the laptop lid yet on my vlc player it decides to loop like 10/20 seconds of the song playing through my headphones when playing on the speakers it's fine so I believe, i have tried re installing the drivers (no luck) tried window update (that caused the problem can't roll back) and i have tried windows diagnostic service and that says there is an error, yet when i try to fix it it says that the headphones are not plugged in or nothing into that socket.
Any help would be grate,
Many thanks, David
P.s. my laptop is running windows 8 (hp pavilion DM1 amd E2)
