Any way to keep audio from desktop program going?
    I would really love to play music from musicbee which is a desktop program and shut screen off to save battery. Metro apps will but they are crappy for playing music.
    This allows you to shut screen off but not put tablet to sleep? Or is this just for desktops?
Who knows Audio Recording program for windows 8.1 (64bit)
Looking for a audio recorder/grabber to record audio that i play from my computer.. believe it or not, i used to be a mac user and used programs like audio hijack and etc.. now i'm with windows 8.1 and what the heck do i use to grab high quality audio and save it to high quality files on my...
EXE program suddenly on desktop !!
Win. 8: Hello - today on my desktop i saw a 'program' to install, clearly showing the Win. ''shield'' icon & it was an 'exe' file. Since i have my Update preferences to ''off'' - (ie) that i will check regularly for any updates and choose what i want to install (i don't want...
Any way to have a certain program use my TV as audio ?
So when playing movies on netflix and or if i want to play music while playing a game is there any program or way that i can have my TV which has audio on HDMI do this ? like some program that will allow me to assign like netflix and my video software switch to my video card audio instead of me...
Using Desktop Beats Audio AND External Speakers -Possible?
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
How can I delete the SkyDrive Desktop program?
How can I delete the SkyDrive Desktop program, I try but it keeps saying it's open.
Software and Apps
Email program for Desktop?
I cannot use Opera because I can't get it 'verified' through my mobile/cell phone. Can somebody suggest a good email program that will open on the Desktop so that I can send attachments from my Desktop. Thanks!
Browsers & Mail
Win 8 stuttering, video, audio, desktop use
after about 10 to 20 minutes of use the whole computer begins to stutter, audio video... the mouse skips around and it is almost unusable just upgraded from 7 ultimate to 8 pro, and ive included the diagnostics what in the world is causing this?
