RCA HDTV not playing sound when VGA cable is plugged....
    Windows 8 Professional
    I recently purchased a RCA HDTV ,I am trying to get the sound working from my TV. However I can't because it says "not plugged in", I have no idea whats wrong with it. please watch the video to give you a full understanding of my problem.
    First, establish if the TV has a PC audio input.
    The VGA connector will only display the video, not sound.
    For sound, run an audio cable from the headphone output of the laptop to the PC audio input on the TV. On the TV, switch to the PC input as the Source.
    The HD TV I have (a Vizio) will not let me select both a separate Video, such as DVI, and a separate audio at the same time. That may be the case with this one, too.
    Run a separate audio cable, as suggested, and then check the TV to see if its possible to select separate (different) video and audio connections.
    If the TV has a VGA input then it most likely will have an AUX for PC sound. Look at the picture.
    Windows 8.1 Pro x64 / Windows 7 x64
    Well, if you don't have sound plugged in from the laptop to the TV, you should hear the sound coming out of the laptop speakers first.
    Also make sure you're plugged into the headphone jack and not the mic/line in jack. If you can't hear audio from laptop speakers, try headphones. If that doesn't work, you need to look into your PC first before you mess with the TV.
AMD HDMI Output 'not plugged in', no sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel Playback Devices
Sound Plays Through Speakers When Headphones Plugged In
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Ethernet cable plugged in, Windows says not
Hello everyone! So I've had this problem before and I went to a PC-Shop that fixed it by putting another driver on the PC. But now I have a new PC and after 6 months without any problems Windows suddenly decides there is no ethernet cable plugged in the PC. I've googled for hours and hours...
Network & Sharing
Need help with my laptop connected to my HDTV (HDMI Cable)
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI....
Graphic Cards
LG TV not playing sound when connected via HDMI cable
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
Sound no longer automatically switches to HDTV
OK so I always watch video and movies with my ASUS computer attached to my HDTV. I have never had a problem then one day the audio stopped switching to my tv automatically. I also use surround sound headphones sometimes which require a USB connection and the audio no longer switches to them...
