RCA HDTV not playing sound when VGA cable is plugged....
RawadMerhi
I recently purchased a RCA HDTV ,I am trying to get the sound working from my TV. However I can't because it says "not plugged in", I have no idea whats wrong with it. please watch the video to give you a full understanding of my problem.
[video=youtube;j8YwXEJJsNY]http://www.youtube.com/watch?v=j8YwXEJJsNY[/video]
    Windows 8 Professional
First, establish if the TV has a PC audio input.
The VGA connector will only display the video, not sound.
For sound, run an audio cable from the headphone output of the laptop to the PC audio input on the TV. On the TV, switch to the PC input as the Source.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
The HD TV I have (a Vizio) will not let me select both a separate Video, such as DVI, and a separate audio at the same time. That may be the case with this one, too.
Run a separate audio cable, as suggested, and then check the TV to see if its possible to select separate (different) video and audio connections.
If the TV has a VGA input then it most likely will have an AUX for PC sound. Look at the picture.
    Dell E6410
    Core i7 M560
    8 GB
    nVidia NVS3100
    120 GB SSD
Well, if you don't have sound plugged in from the laptop to the TV, you should hear the sound coming out of the laptop speakers first.
Also make sure you're plugged into the headphone jack and not the mic/line in jack. If you can't hear audio from laptop speakers, try headphones. If that doesn't work, you need to look into your PC first before you mess with the TV.
    Windows 8.1 Pro x64 / Windows 7 x64
    Dell Precision M6500
    Intel Core i7-740QM
    16GB
    NVIDIA Quadro FX 2800M
    1920x1200
    Samsung 840 PRO SSD (Windows 8.1)
    OCZ Vertex 2 SSD (Windows 7)
    WD Black HDD (Storage)
