Microphone to Headphone port
    How do you turn your microphone port or line in, to a headphone port or line out port. For a while I would plug in headphones into the mic port and it would bring up a dialog saying I could change it to another headphone port but it never worked. Now it doesn't even pop up. I want this so when I go on long trips my girlfriend and I could watch a movie together using 2 pairs of headphones.
    WIN 8.1
    Windows Server 2012 R2 / 8.1
    Hi Erics9971,
    Welcome to the forum
    Very cheap solution just purchase a headphone splitter to be able to use two pairs from one jack.
    Just for an example:
    Belkin 3.5mm Headphone Splitter - White: Electronics
    Loads of different types on the Internet, search for headphone Splitter.
    hope this helps
Microphone recording through headphone ear buds
I recently built a pc, and for some reason when I attempt to use my mic to speak to others over games, skype, teamspeak, etc. the mic doesn't pick up my voice. After a few hours of messing around with the settings, I discovered that I am able to talk through the ear buds, but not the headphones'...
Display Port Link Failure, Active Display Port->DVI
I have 3 monitors connected to an AMD HD5770 graphics card. Two monitors connect via HDMI, and the third through a Sapphire Active DisplayPort->DVI adaptor. Things have been working fine for years, but recently I started sleeping my computer when I am not using it during the day, as opposed to my...
Graphic Cards
router not passing port scan after opening port
47143 47144 47145 so i opened my port 25565 (or so i thought) went to test to see if its open on multiple sites and....all of them say its closed. :confused:
Network & Sharing
Virtual COM port error: COM port needed for CDMA phone
CDMA software requires a COM port to communicate with a cell phone. I'm using HW Virtual Serial Port v3.1.2 (single port, standalone install). I have a separate modem and router. My Win8.1 PC is hardwired to the modem. Windows firewall is off. Windows Defender is off. Motorola Mobile Drivers...
Drivers & Hardware
Messed up headphone audio; want to check headphone jack
Mic through headphone
Hi. I am having a VERY frustrating issue. I bought a Turtle Beach Earforce PX-21. (link to headset here). I use the headset for chat using teamspeak 3 while playing games. (link to teamspeak here). My motherboard is a ASUS SABERTOOTH 990FX R2.0 (link to motherboard here). The problem is pretty...
Speaker and headphone together my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug...
