firstly this is my first post so sorry if i sound noob.
ok so i installed windows 8 consumer preview build 8250 x64 last night. everything seems to be working correctly other than my sound. i am using VT1708s by via embedded in a asus m5a78l-m/USB3 motherboard now the problem is the sound is working fine via my HDMI connection but via the 3.5 mm jack the sound is all strange and un-usable its like according to my friend it sounded like it thought it was digital when it is analogue.
i have tried installed the windows 7 x64 driver from both asus and VIA but it didnt work still the same problem. i had to run it in compatibility mode.
I'm in the same boat with my board....only difference is my sound works with the windows built in driver but I can't get the VIA driver to load at all.
well it doesn't matter what driver i use i get sound via HDMI but not working correctly via speakers. although on the actual windows driver their is no speakers output at all.
How would I at least get the Windows built in driver to work then? I'm having this problem as well, but a temporary solution is better than no solution at all.
Anyone give this a go?
answers.microsoft.com/en-us/windows/forum/windows_8-hardware/no-working-sound-drivers-via-vt1818/e23f3927-e92e-46d7-8477-9bfc4618fbeb
A more detailed set of directions may be in order but perhaps someone can work it out?
Yes. I installed it in compatibility mode, then opened up Device Manager and uninstalled it. For some reason, that made the default Microsoft HD Audio drivers read my 3.5mm speakers.
