Realtek or AMD Audio Driver
thummel
What would be a better option for a Sound Driver? I used to have "Realtek High Definition Audio Codec" when I used Windows 7, but a few months ago I installed Windows 8.1 and just kept the generic "AMD High Definition Audio Device". Haven't really noticed that much of a difference. That's why I want your guy's opinion based on AMD vs. Realtek - (Quality, Performance, etc.)
Thanks!
    Windows 8.1 x64
    Waterfox/Firefox
    Kaspersky PURE 3.0
Realtek is for the onboard high definition audio codec built onto the motherboard. It is what you use when simply using a desktop or laptop.
AMD is the audio driver for HDMI, for when you have a tv attached to the computer or desktop. This driver is installed along with the video driver itself.
You should download/install the latest Realtek HD driver from their site.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
Just tried installing the latest Realtek HD Driver from their website and I get this error message:
Any idea what's causing this? I made sure it is for Windows 8.1.
    Windows 8.1 x64
    Waterfox/Firefox
    Kaspersky PURE 3.0
Nope, no idea. Maybe you don't have Realtek at all or Realtek HD.
Could be Realtek AC'97 (especially if older board) or some other.
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
Since you make/model and/or motherboard information is unknown, try going to the manufacturer's website and look for a compatible 8.1 audio driver.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Only odd thing is that when I had Windows 7 & Realtek installed, I still have the same Motherboard as I do now. So I don't know what's causing it to error when installing.
My Motherboard is a Sabertooth 990FX R2.0 from ASUS.
    Windows 8.1 x64
    Waterfox/Firefox
    Kaspersky PURE 3.0
Still getting the same error as before; :cry: Tried downloading the hotfix as well but same thing persists.
    Windows 8.1 x64
    Waterfox/Firefox
    Kaspersky PURE 3.0
Longshot here. Try uninstalling the existing audio driver completely, reboot to make sure it is uninstalled, and then check Windows Update for an optional audio driver update.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Google the error code and follow what you find. The method with safe mode etc and all that good stuff will fix it.
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
Ok, MasterChef seems to have this under control so there is no sense in trying to go in two different directions. Please work with him directly until your issue is resolved.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
heh it's all good. I read some stuff before that seemed promising. Whatever gets it going.
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
You may want to download the file again, in case of file corruption.
Realtek
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
