Realtek or AMD Audio Driver
  1. #11
    Ok, MasterChef seems to have this under control so there is no sense in trying to go in two different directions. Please work with him directly until your issue is resolved.
  2. #12
    heh it's all good. I read some stuff before that seemed promising. Whatever gets it going.
  3. #13
    You may want to download the file again, in case of file corruption.
Page 2 of 2 FirstFirst 12
Latest Realtek HD Audio Driver Version for Windows 8
Latest Realtek High Definition Audio Codecs 6637 Last Updated: October 18th 2016 DRIVER VERSION: (32-bit and 64-bit Windows) Download at:
Realtek AC97 audio driver (not HD driver)
After installing W8 on a Toshiba satellite laptop, all went well except Realtek AC97 won't install. Re-installing the driver didn't work. Windows reveals a code 10 and mentions the driver did not install correctly. Naturally there are no sound devices present with this occurrence. Plugging in...
Realtek HD Audio Driver stops working when comp sleeps.
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
Realtek HD Audio Driver(Windows 8.1 version) Issue
Recently I decided to go ahead and update to the Windows 8.1 version of the Realtek HD Audio Driver. I procrastinated because it told me I'd have to uninstall the original audio driver and I knew it would take a while to do everything needed. It didn't help that after uninstalling the original...
Realtek Audio Manager Driver Turns Off After a While
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Win8.1+Realtek HD audio:Win driver or R2.71 ?
Hello My MB has ALC898 audio chip. Should I stay with the default Windows 8.1 HD audio or install the driver from Realtek (which is R2.71 the latest version) My system is used for gaming BTW. Thanks.
Realtek HD Audio device driver
Thanks for anyone, who helps me :D I have "an old fashion motherboard,, with realtek's VT1818S High Definition Audio 8-Channel soundcard build in to the Asus m4a77 motherboard. Usually with W7 windows i had to install the driver from asus's website... so far when i get to the installation point it...
