No sound when using optical digital output
    Windows 7 x64 Home and 8.1 x64 Enterprise
    Onboard Sound: ALC 888s
    external DAC/amp: Fiio E17
    Connection: ALC 888s out----Optical digital cable-----Fiio e17 SPDIF in
    I do not get sound when I set Realtek Digital Output (Optical) as my playback device. I tested the cable and fiio e17 on my PS3 and it works fine. I tried on windows 8.1 and windows 7 and it has the same result. I notice that when i connect or disconnect the cable, Realtek does not say anything.
    I have the latest sound drivers and i made sure the sound format was stereo and not surround.
    EDIT: fixed. I opened up my computer and i switched to another spdif header. Maybe it was defective or it was loose.
AMD HDMI Output 'not plugged in', no sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
FIX - AMD HDMI no sound output to monitor speakers
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Realtek ALC889 Win 8.1 - No digital coax output detected
Hello everyone! First of all, I'd like to apologize if this issue's been solved in another topic already, but I couldn't find anything - if such a topic exists, please feel free to post the link :). Now, onto the issue; first of all, the motherboard I am using is a Gigabyte GA-P67-UD5-B3....
No sound on start-up, Win8 needs time to output sound
Changing sound output -different listening positions
Hi all, I was wondering if its possible to have a software switch which changes the in-use speakers. For example, I'm typing this sat at my desktop. The speakers are optimised for the person in this chair. Are there any media players (or other programs) which could switch the speakers over...
HDMI Sound output issues
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
Dell m1710 and no digital audio output i win 8. (usb cards that work?)
I hae a dell m1710, installed win8 rtm on it. In win 7 i have 2 options of digital audio out: 1. Turtle Beach Audio Advantage Micro usb with optical S/PDIF out 2. Dell composite video adapter with digital coax out. Sigmatel high definition audio codec In win 8 i tried first the Audio...
