help! razer ac-1 sound card ( chipset CMI8788)
    It was working fine in the developer preview, while now in the consumer preview I can't install the drivers, it tells me it is not plugged in and in the device section it is shown as "multimedia audio controller" any workaround?
    i actually found solution for this problem U have to install these drivers: AC-1 Vista drivers v.2.23 - link: Razer Barracuda AC-1 Driver v2.23 // Youre welcome!
    Have a nice day.
Chipset overheating - Graphic Card to blame?
Hello. There's going to be a lot of guessing from my part in this post, and the post will be lengthy -I apologize for that. My old computer (Asus rampage II Extreme, Intel i7 920) recently died. I believe the north bridge on the motherboard overheated and fried. (Not sure, wasn't able to test...
Drivers & Hardware
Sound Card not working
Irql_Driver_No_Less_Or_Equal (cmudaxp.sys) -- Sound Card?
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
BSOD Crashes and Debugging
upgrade b75 chipset to z77 chipset - prebuild issue
Hi guys, some advice please. I have a friend who has passed me an advent DT2412 desktop computer. The mobo has failed (MSI B75MA-P45) and he wants to replace it with a MSI Z77A-G43. I suggested that this would need a fresh re-install as its a different chipset but the question I want to...
Installation & Setup
Sound Card Recommendations
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Virtual Sound Card?
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
