Soundblaster card & microphone on headset not working
    The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the microphone. I'd like to use this for teamspeak, but there doesn't seem to be anything that I have found on google to solve this so far, or anything that I've figured out on my end. I have attached a screenshot of what is happening in my audio manager. When any headphones/earphones are plugged into the green jack, they work and sound is audible, however in the audio manager it still says that no headset is plugged in even with them plugged in & working.
    - As well, I have a d945gtp motherboard
    - I also have an actual sound card in the motherboard ( a soundblaster live sb0060 ) currently doesn't work at all, and shows up in the device manager as 'multimedia audio controller' with a yellow exclamation mark. If I could get this working instead, that'd be much better too as an alternative fix.
    Any help is appreciated, thanks. =)
    win8.1.1 enterprise
    hi, as for the sound blaster card I think you might as well remove that ,chance of getting win8 drivers for a win95/98 sound care are slim .
    plugged into the green port they are working as speakers .what happens when you plug them into the pink port
    edit , just google you board and it seems obvious this is not the computer in you system specs, so what are the specs of the computer you are trying to use and what os are you using.
    if you are using winxp you can check google to get driver for the soundblaster .
    soundblaster live sb0060 - Bing
Im having trouble with my microphone/headset..
So the other day i bought a Logitech for £15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Headset Microphone not working
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
RealtalkHD Mic stops working when I plug in my headset
Hello~ I was recording with my internal realtalk hd mic on my laptop, but it stops working everytime I plug in my head set. There's nothing special about this headset, and there's no microphone on it. Sadly, my RT mic does this with any headset I use. It's frustrating when I unplug my headset and...
Microphone is not working
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
Beta Drivers for the SoundBlaster Audigy 4 and Live! 24-bit sound card
Beta Driver Creative Sound Blaster Audigy 4 Driver (Beta) Filesize : 40.42 MB Download Release date : 4 Oct 12 File Name : SBAX_PCDRV_WIN8_BETA_LB_2_18_0017.exe This download is a beta driver providing Microsoft® Windows 8 support for Creative Sound Blaster® Audigy® 4. For more...
Drivers & Hardware
