IDT Audio CODEC preventing Windows 8.1 pro from sleeping
    I've been trying to configure my brand new hp PC with Windows 8.1 pro to auto-sleep but I have been unable to do so. If it hit the power button or select sleep from the menu it will sleep, however.
    I ran powercfg/energy and it appears from the report that this is the issue:
    System Availability Requests:System Required Request
    The device or driver has made a request to prevent the system from automatically entering sleep.
    Requesting Driver Instance HDAUDIO\FUNC_01&VEN_111D&DEV_76E0&SUBSYS_103C2B04&REV_1001\4&3288eeae&0&0001
    Requesting Driver Device IDT High Definition Audio CODEC
    ****Does anyone have an idea why an audio codec would prevent sleep? Is there anything I can do? Thanks so much for your help!!
    Windows 8.1 Enterprise
    The first place to check is to see if any drivers need updating.
    This a default setting in many operating systems to prevent the system from turning off while playing audio/video. Do you have Apps or Programs still open that would require the use of audio/video? Maybe Netflix? iTunes?
Lumix RAW Codec 64bit for windows 8.1 needed
Dear All Happy New Year to you! I have a problem with software asking for LUMIX RAW codec 64bit for windows 8.1 for my camera Panasonic Lumix FZ200. I cannot find this, only for 32 bit, but my PC is 64bit. I tried to install it anyway, but it was not accepted. Can anybody help me please?...
Software and Apps
DTS-HD in Windows 8 app - no sound, is this a codec issue?
Hello! Having a bit of a problem and trying to see if there is an easy solution. I have a Surface Pro and I want to watch some video on it. I wasn't able to find a specific video app that would play MKVs, but I did find Files&Folders which has a built in player that actually does! Been...
Which of these 2 codec,s should I use?
I have a Windows 8 system and I am into video recording and burning onto dvd-r disc. My question is this: Should I install --> "K-Lite Codec Pack 10.15 (Full)" or "Windows 8 Codec Pack 2.0.1" Thank you so very much and any reply and help is greatly appreciated. God Bless, Artic
Windows not sleeping
I have my options to turn off monitor after 10 minutes and put pc to sleep after 45 minutes. None of these work, I have run the command to see why and it says nothing that is preventing my pc from going to sleep, what am I doing wrong?
Is there a Windows 8 Codec available?
Like on Windows 7? I'd like to use the Windows 8 Video App to play FLV Files, but it seems like I'm gonna need to install Wondershare Player on W8 like I had on W7
Software and Apps
New Realtek HD Audio codec drivers 2.68
Realtek HD Audio 2.68 audio driver download from To easily install, go to device manager first. Then right click the Realtek audio, choose uninstall and also check the box to delete the driver. This saves you a reboot in the process to install. When you run the installer, it won't...
Drivers & Hardware
Sigmatel High definition codec installed but no audio
I recently installed the dev preview on a partition to my main hard drive and my audio service will not start here is the error 1079 the account specified for this service is different from the account specified for other services in this same process but i went through and checked and they are all...
