How do you enable speaker output while headphones are on?
    Windows 8, iOS 6.1.3, Ubuntu
    ...for SELECT programs? For example, I like to game with headphones on, I listen to music with headphones on and more. I don't like to unplug them every time I'm done, that's too confusing and more importantly, I FORGET ALL THE TIME. So, if anyone could kindly help me find a way to play my "Free Alarm Clock" (please Google to find it because I'm afraid to post links) through the speakers despite having headphones plugged in, I would greatly appreciate it. I use it not only to wake up but also to remind me of other daily things.
    Just to be clear: I'm not looking for something to play sound through headphones and speakers simultaneously. That would defeat the purpose.
    Thanks in advance!
    A command would also work, I believe.
    Southern California
    Windows 8.1 Pro with Media Center x64
    Hey mate,
    Don't be afraid to post links, just make sure they aren't walware lol.h
    When your headphones are plugged in, do they show up in sounds?:
    If so, that is a good way to switch it. If not, see if you can't find out more about sounds with your sounds control center. I think you only get such a thing if you have a sound card. Some built-in ones come with such a control center. Take a peek in there to see what you can find.
    That's a tough question. Windows only allows one default audio playback device. Thus if the Speakers are set as the default playback device any audio will go through that. If you have a sound card that allows the speaker to be on when you plug in headphones (my RealTek will allow that) then whatever sound will come through both the headphones and speaker.
    But, you can't have certain programs/sounds only on the speakers. Plus, if you are listening to whatever on the headset you may not hear something over the speakers if that were even possible.
    It depends on a few things:
    What your Audio Manager settings allow and what application you're running as well as the various settings of the application.
    Attachment 36727
    Attachment 36728
No sound from speaker/headphones, can't find any errors.
A couple of days ago, I decided to move my tower from my desk to the floor. Everything was working beautifully up until then. I opened it up and removed some dust. After putting it back together, the monitor wouldn't register anything. I left it for a day, came back, and the monitor magically...
Replace Speaker Cover
Hello, I have a Toshiba Laptop Satellite L875D-S7332. I need to replace the cover that is on top of the speakers (Speaker Cover). I want to do this myself! Can someone tell me how to do this or refer me to another information source that will teach me how to do this? Thank You, heaven5733
speaker fill windows 8?
Hi, I have an Asus G750 laptop running windows 8 and I was wondering if there is anyway I can hook up my 5.1 home theater system to my laptop and get it to put out of all the speakers? I know there was a setting in windows 7 called "speaker fill" and it would put out through all the speakers,...
Speaker Problem
While playing a video or games or any app that has sound... the sound suddenly dissappears if it is too loud. At first I thought it might be the driver... so i replaced HD Audio with Conexant... but the problem still persists, which lead me to believe that it coild be probably the speaker's...
Speaker and headphone together my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug...
External speaker fail
The internal speaker works fine, but when I plug in the external speaker, (speaker plug + USB) it seems to mute the whole system. Anyone else with the same issue?
