Audio routing issue
    Austin, TX
    Audio routing issue
    First of all, i'd like to mention that while I'm fairly tech savvy, I know next to nothing about audio stuff.
    Now, I have an Xbox 360 that i connect to one of my computer monitors via HDMI cable. I'd like to display on the monitor, but have the audio routed through the monitor, to my pc, where i can use my desktop headset to listen to the game audio.
    Now, what I've done is jury-rig it to work by connecting the audio out from my monitor to a mic port on my desktop, and then "listen" to that microphone from my pc. It works, but there's a ton of audio static, which is disheartening.
    So, i ask, is it possible to do this better, or is this about as good as I'm gonna get?
    If you are going to do it like this, you should change the input port (if you only have one on the machine) to line in instead of mic.
    If you have both mic and line in ports, take the cable out of mic port and put it into line in (typically blue color.)
    That will fix it all up for you.
    Make sure you are using a 3 wire cable, so it works in stereo. The ends of each side of the cable should look like this:
    Notice that there are 3 distinctive parts to the plug end. One near base, one in between black lines and one at end.
Audio routing issue
Dual audio issue Windows Media player Shark007 Codecs
Hello all, I just installed the Shark007 Codecs and reboot the PC. Because, I need to play.MKV video files. I didn't change that plugin settings. Now when I play the AVI video files which has dual audio (two languages), now Windows Media player automatically playing both audio sounds. When I...
Realtek HD Audio Driver(Windows 8.1 version) Issue
Recently I decided to go ahead and update to the Windows 8.1 version of the Realtek HD Audio Driver. I procrastinated because it told me I'd have to uninstall the original audio driver and I knew it would take a while to do everything needed. It didn't help that after uninstalling the original...
Windows 8 Routing to External IPs instead of Internal IPs
I work for a company that uses multiple servers both internally and externally. We have some servers on-site that are occasionally moved to off-site collocation servers in order to test fail-over protocols. However, when the servers are moved the IP addresses change and our NOC team updates the DNS...
Network & Sharing
Audio Issue in Win 8 CP x64
i'm getting a crackling noise / robotic sound from my 5.1 speaker connected to pc via 3.5mm audio jack ... i'm using win 8 CP x64 ... motherboard has inbuilt audio chip by VIA ... audio codec - VT1708S .... though i'm using the latest driver ver. (v9.8), it can't solve the issue .. tried running it...
SoundMax audio issue
I put Windows 8 Developer's Preview on this computer a few weeks ago and have not had any issues 'til yesterday. I had no audio. I checked the drivers, checked the cables, speakers, powersupply (for the subwoofer/speakers) and couldn't find anything wrong. Except, no audio (but I didn't...
I am facing a crackling audio issue since installation of Win 8 CP
Hi, I am facing a crackling audio issue since installation of Win 8 CP. I have a Creative 5.1 VX Card and have updated also latest Win 7 driver as available from Creative 's Website. I also disabled on-board audio from BIOS. but still there is no luck with crackling of audio. Creative SoundBlaster...
Drivers & Hardware
