How can I play APE sound files in WMP 12 64 bit?
    Hello... I searched the forum for 'APE'.. some amusing threads about going ape**it, some about converting APE to FLAC...
    I don't want to convert my APE audio files. I want to play them directly in WMP 12 just like I could in previous versions of WMP (on XP, for example).
    My WMP plays mp3 and FLACs fine. I installed something last week called Shark007 which enabled me to add APE files to the player, and indeed play them. However, it also caused WMP to crash every time an mp3 finished and the next track in the playlist was a FLAC, and vice versa. In other words, it couldn't handle switching from one type to another in the playlist and crashed. I had a hell of a game uninstalling that ... Back to before now... though.. stability.
    Is there a codec or something that will enable me to drag a sound file with a .APE extension into the Play tab on the right side of WMP 12 (it doesn't even let me do that at the moment) and play the file ok ?
    There was one on but when I checked the last 5/6 reviews, they were terrible - had a lucky escape there. Didn't bother with it.
    The only codec I currently have installed is 'Media Foundation FLAC Codec'.
    Windows 8 - 64 bit
    Running WMP 12.0.9200.16579 - 64 bit version.
    Check out the K-lite codec pack. It supports .ape
    About the K-Lite Codec Pack
    windows 8.1
    windows 8 codecs pack for windows media player wmp 12 and media Center version 2.0.1 download here Windows 8 Codecs Pack for Windows Media Player WMP12 and Media Center
    Well thanks for the help!
    I installed the K-Lite pack. It enabled me to play APE files in my WMP 12. Great? Not quite...
    When I was playing my playlist and it tried to move from playing an mp3 to the next song being a FLAC, WMP crashed. It couldn't handle the transition from mp3 to FLAC.
    I uninstalled K-Lite and installed the Windows 8 codec in the message above. That didn't crash anything but it didn't change anything either. My APE file won't play in WMP 12 even with that installed.
    Seems to me I need to re-try the K-Lite with certain options selected for FLAC when I am selecting its install options in WMP file associations. I am confused what to choose though. All rather frustrating. I seem to be close, but not close enough!
    Any more advice? You've been very helpful so far!
    I did it! I re-installed K-Lite and deselected EVERY SINGLE file association completely except for the APE option for WMP. That was the only option I checked during configuration during the install process. After it finished, my WMP playlist plays perfectly and moves from mp3 to FLAC, back to mp3, to APE and back to mp3 as if they were all one format of audio. Seamless!
    Thanks helpful people
Can't play sound on TV through HDMI - ASUS, Windows 8.1
Hi everyone, I have been struggling with this for weeks - whenever I plug my computer into a TV through an HDMI cable, the screen visual transfers perfectly but no sound comes through the TV. Please note that I have scoured the forums and have tried all of the basic suggestions that people...
MV files won't play
Movies that I take with my camera have always played. Now suddenly they won't. I checked file defaults and there is no file to associate. It just wants me to pick a program from the store... and pay. I know I have programs installed that can open these files... how do I assign one of them to MV...
Software and Apps
Files are there, but they don't play ???
I wanted to access some multimedia files today and I realized that they don't play. I remember copying them from an SD Card weeks ago (Therefore, most likely it was a FAT formatted Card). What can be causing this? Files exist with original file size, but they don't play (tried in different...
Windows Sound Files Exist But Cannot Access / Play: How?
My new HP Pavilion with MS Win 8.1 includes all of the default MS Win sound files. I cannot access them to play for all users (family use with no password on accounts). REQUEST: I would like a 'How-To' on both accessing and getting MS Win 8.1 default or any sound file them to play during a...
Phone videos downloaded to laptop won't play with sound
I have an android phone, make videos, download to laptop and they play but cant hear the sound. I've tried downloading everything and nothing works. Can you assist?
Headphones dont play sound on laptop.
Hi, I have a HCL laptop with Windows 8 Pro x86 installed. Whenever I connect my headphones I don't get any sound from it. I have gone to my "Playback Devices" and selected "Show Disabled Devices" and the headphones are not listed there. What can I do to work around this problem ? I need my...
IE10 in Windows 2012 server -- cannot play video - sound OK
Hi there the version of IE10 shipped with Server 2012 seems to have a defect -- can't play video from web sites -- sound is fine. Not sure if this is actually a real problem as you don't usually do much browsing on a server -- but as this version of IE10 is nearer RTM than that shipped with W8...
Browsers & Mail
