Windows 8.1 no sound after uplugged the cables
jan24
Hello,
I'm new to this forum.
My problem is that I can't get any sound out of my pc anymore.
Things I have checked so far:
  • I got all cables plugged in.
  • Runned sfc /scannow.
  • Set my speakers to default output.
  • Reset the settings to default of my speakers.
  • Uninstalled the drivers of my audio ouput (through device manager) and reïnstalled realtek (newest version).
  • Checked device manager but no yellow or red signs are displayed there.
  • Of course rebooted my PC couple of times.
The odd thing is when I configure my speakers and quadraphonic my L and R speakers doesn't get any sounds but LA and RA does give sound out of the speakers and headset.
Screenshow below shows the ones that giving sound in the red box.
Anybody has any idea?
Any advice is welcome.
Thanks in advance.
Greetings,
Jan24
    Windows 8.1 Pro N
    Logitech X-530
No sound at all...???
Did you try various programs..??(foobar, winamp, mpc, vlc et al)
Did you check 'device manager' for yellow alerts..??
Did you check the speakers with a different device..??(ipod etc)
Bios..??
Oh, and welcome to eightforums...
    Win8.1 Pro, Desktop Mode
    Me
    AMD FX-8150
    Gigabyte GA-890GPA-UD3H
    8.00 GB Dual-Channel DDR3 (9-9-9-28)
    AMD Radeon HD 6570
    Creative X-Fi Titanium
    PX2710MW
    1920x1080@60Hz
    1x1TB Western Digital WDC WD1001FALS-00J7B1 ATA Device Caviar Black -
    4 x 2TB Seagate ST32000542A -
    1 x 4TB Seagate External
    Antec
    Noctua NH-D14
    Logitech Illuminated Keyboard K740
    60meg cable
    Cyberfox
    AVG Security Suite
Bios..??
Thanks for your reponse.
Well I do get sound at the 2 speakers in the red box on the picture above.
Yes, I did try various programs like: Windows Media Player, YouTube and VLC.
Yes, I did check the device manager and no yellow alerts appear.
On my laptop the speakers / headphone working fine like they should.
What should I check into my Bios?
    Windows 8.1 Pro N
    Logitech X-530
did you try the stereo setting
,what speaker[make model #] system are you using
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Yes, I did try stereo (where I have it normally on) but it doesn't gives any sound at all.
I use a Logitech X-530 as speakers.
    Windows 8.1 Pro N
    Logitech X-530
I've got the same speaker's on my pc. This will sound weird as they're 5.1 speaker's. With the last few driver updates from Realtek for Windows 8.1, you need to set them as 7.1 speaker's, then go into the Realtek HD Audio Manager program and configure the Speaker Configuration & Room Correction setting's to yur liking.
    Windows 8.1 Pro w/Media Center x64
    self built
    AMD FX 8350
    Asus Sabertooth 990fx r2.0
    G-Skill Ripjaws-X DDR3 2400 16 gbs.
    MSI N760 TF 2GD5OC
    on-bord Realtek ALC 889/ALC 892
    ViewSonic VX2250wm-LED
    Samsung 840 Pro 256 gb. ssd. & Seagate Barracuda 7200.14 3.o tb.
    Corsair HX-850 watt
    Corsair Carbide 500r White
    Corsair Hydro Series H-100, 3 120mm. & 1 200mm. case fan's
    Logitech wired
    Logitech wired
    30 m.b.p.s.
    IE 11 & Firefox 26
    BitDefender Internet Security 2014
    Iomega Pro Series U.S.B. 2.0/eS.A.T.A. 2.0tb. h.d., Seagate Backup Plus U.S.B. 3.0 3.0tb. h.d., Hauppage WinTV HVR-1850 t.v. tuner, Logitech x530 5.1 speaker's, Logitech c615 webcam, Logitech h150 headset, M.S. Xbox 360 wired gamepad & Xbox 360 as W.M.C. extender
This didn't work for me.
Also that link you sended me is a program where I need a license for.
    Windows 8.1 Pro N
    Logitech X-530
So.. I have tried to totally reïnstall my PC to Windows 7.
But still no luck with the sound, still the exact same problem.
It ***** I had to reïnstall my PC for this and didn't come to a solution.
Atlhough this tells us where not to look atleast.
I'm scared it's a hardware problem and so I already took contact with Asus and now waiting for response.
    Windows 8.1 Pro N
    Logitech X-530
