Solved System Wide Equalizer
Yanniclord
Norway
Well i know that the Realtek Audio Manager applies for Cable In/Out. But what about Bluetooth? There is no tab for the Bluetooth Device Configuration, so i cant equalize the bluetooth. Is there any equalizer for Bluetooth Headphones? Since my Headphones also have a Mic, so i can talk with them to (almost all Bluetooth Headsets have that anyway), and so i want to equalize the sound, so is there any equalizer for Bluetooth? Please if you know, tell me. Thank you.
    Windows 8.1 Pro x64
    Intel i5 4440 Quad Core 3.1GHz
    ASROCK EXTREME4 Z97
    18432 MB (18 GB) DDR3 RAM
    NVIDIA GEFORCE GTX 970 STRIX x2 SLI
    Realtek HD Audio Manager (Integrated Sound Card)
    Samsung S22D390, Oculus Rift DK2
    1920x1080, 32bit ; 1080x1920 (Oculus Rift)
    INT1: MTFDDAK256MAY-1AH12ABHA 256GB SSD
    INT2: WDC WD30EURS-63SPKY0 3000GB HDD
    EVGA SUPERNOVA 750B1
    NZXT Phantom 820 White
    CPU: NZXT Kraken X61, Case: Front: 1x 200mm, Rear: 1x 120mm, Top: 2x 200mm, Side: 1x 200mm
    Logitech Orion Spark
    SpeedLink DECUS
    100 MBP/s Download and 10 MBP/s Upload. 8 MS Ping
    Malwarebytes Anti-Malware
    Using two programs that modify audio.
    1: Viper4Windows for better sound quality and bass regulations and that.
    2: MorphVOX Pro to modify the voice and use soundboards.
