Location of volume mixer settings...?
  1. #11
    Exeter, UK
    Windows 8.1 Pro x64
    Thank you again, MilesAhead! Actually before I came to your new post I'd experimented further, and found that I got a full restore of the registry key implemented if I exited all running programs for which I'd set a sound volume, then rebooted (okay, I expect just logging out would have sufficed). So, yes, it's clear that the remaining issue relates to the way that the registry-in-memory is or isn't flushed out - and with the interfering effect of affected programs actually running at the time. It's becoming more simple now that I know how to work round the potential problems.
    I have also found a little utility called Registry Key Jumper, which not only directly enables one to jump to a 'favorite' registry key listed in the program, but actually to have the program make a shortcut for the key, so you just click the shortcut and the key opens straightaway in Regedit; I can then export the key. So, I haven't yet got a one-shot utility that would enable me to save the key at just one or two mouse clicks, but I am getting close. I now have a shortcut for the mixer settings key in my (Classic) Start Menu, and it works really nicely. I suppose the thing to do also is to make a shortcut for the saved key in whatever location I decide to keep it, and have that shortcut next to the one for the registry key itself, and then I would be very close indeed to the facility that I was wanting for saving and restoring my volume settings.
  2. #12
    Windows 8.0 x64
    The jumper sounds interesting. I have been using RegJump from SysInternals. It opens regedit to the key passed on the command line. But it has no facility to create a shortcut(although one could put in in SendTo and just have a list of keys to pass in.)
    Edit: this looks nice. RegJump command line is a bit old. It brought me to the wrong key at times, which is not good. Good find.
Page 2 of 2 FirstFirst 12
help i cant find volume mixer / audio mixer in windows 8
I am trying to install pinnacle studio 16 ultimate in windows 8. They say it is compatible however I am not getting any sound in the programme. The helpline says I need to turn on sound for this programme in something called volume mixer or audio mixer. Where and how do I find this in Windows 8. I...
Software and Apps
Volume Mixer Problem
Hello guys, So i got a problem on the Volumer Mixer. All started yesterday after i decide to install my new speaker... now is giving a headache to fix to the way that was before. Basically before i could control all the computer volume but now when i go to volume mixer there is a lot of stuff...
Line In is missing from Volume mixer after reboot
I have an audio source connected to Line In and I use the volume mixer to un-mute the input when I want to listen to the audio from that source. I recently started having a problem where after re-booting Line In does not show up in my volume mixer and I do not hear audio from the Line In Source...
Volume mixer becomes unresponsive when I change volume
Volume Mixer Frustration
I have a Qosmio X870-BT3G23 laptop with Windows 8.1 installed. When playing a game, I noticed sound volume got quiet. When I alt-tabbed out of game, I noticed volume mixer sliders were not all set the same. I moved them all up to match main Speaker level, but it is frustrating to keep setting them...
ok... someone look at the screenshot of the volume mixer and tell me those squares belong....
Volume mixer
Hi all, after so long I've been using Windows 8, I noticed this feature(?) in this OS. See attachment. My question is: Why is every application's volume is half of the device volume? I tried moving the bars of the app's volume to match the device volume, but it will go back to the...
