Solved sound bars
Bosslady
nottinghamshire
Hi could someone give me a bit of advice please i have a 60 inch smart tv samsung the sound is not as clear as i would like so i am thinking of a sound bar i have no idea where to start .ie the size .has it got to match the size of the tv has it got to be the same make as the tv ??? any advice appreciated
    windows 8 & windows 7 /samsung tablet 10 1 / acer chromebook/ Lenovo win 8,/10
    samsung
    I E
    AVG /SPYBOT / GLARY UT / CC CLEANER
Not sure you'll get a real answer here. This is a Windows 8 forum, not one that usually deals with something unrelated like this.
    Windows 7 Professional
ok , just thought with it being a smart tv with computer built in some one may have had knowledge of the sound bars
:( also i posted on sound and audio !!!!!!!!!!!!!
    samsung
    I E
Google for "HDTV forum" and you'll find several very good forums that discuss not only hdtv but stereo and all things related.
Sound bars are used to replace the front satellite speakers, you give up some sound quality but they can be better if you are limited in space. If you want really good sound at a affordable price there are several very good, low cost, 5.1 satellite systems on the market. For optimum results you should have a 5.1 A/V receiver, these can be found at affordable prices also. A self amped sound bar would not need any of this.
The newer Samsung smart TV's are pretty cool, easy to surf the net with, but not really a computer.
    Lenova Flex 15
    i5
    8gb
    Itel 4400
    ssd
    IE
    Dell Venue 8 Pro 64GB
    Numerous Win 7 machines
Hi madcratebuilder can i say thankyou for your advice that has helped me a lot . i knew someone would come along with knowledge of my query , this is a brilliant forum i must say it has helped me many times , many thanks again much appreciated :):)
    samsung
    I E
